Activity Forums Panasonic Cameras 1080/30psf to 720/24p
  • 1080/30psf to 720/24p
    Posted by Nel Boshoff on October 5, 2006 at 5:01 pm
    We are shooting 30psf to Sony HDCAM-SR and I need to end up at DVCPRO 720/24p. At the moment we are using Sony SRW-1 field recorder to do the conversion by playing back the 30p as 24p then importing as 24p. Works well but there are temporal changes, more over as I also need the media 30p Im having to recapture the media at 30p this doubles the work.
    Any suggestions would be greatly appreciated.
    Mike Schrengohst replied 19 years, 11 months ago 3 Members · 6 Replies
  • Izoneguy
    October 5, 2006 at 8:48 pm
    Can you capture from the deck directly as a DVCPRO HD file??
    If so you could capture at 720 29.97 and then use
    Cinema Tools to conform that file to 23.976 and then
    that file can be dropped into a 720 24p timeline.
  • Nel Boshoff
    October 5, 2006 at 8:55 pm
    ICan you capture from the deck directly as a DVCPRO HD file??
    I could do that. Do you know if image degradation will occur by conforming the media in Cinema tools?
  • Mike Schrengohst
    October 6, 2006 at 3:07 am
    As long as you stay DVCPRO HD you should not see a visual difference.
    You just have to make sure you are conforming back and forth to many times/
  • Mike Schrengohst
  • Nel Boshoff
    October 6, 2006 at 2:54 pm
    I guess I cant capture as DVCPRo, SRW-1 deck only outputs HD SDI. I can however import a the 1080/29psf as 720/24psf does that get me closer to DVCPRO 720/24p ?
  • Mike Schrengohst
    October 6, 2006 at 3:17 pm
    Give it a try with a short test…
    But even if you deck only outputs HD-SDI
    you should be able to tell FCP how you want to capture.
