Activity › Forums › Creative Community Conversations › 10.1.2 being pushed…
  • Marcus Moore
    June 29, 2014 at 4:38 am
    You want your original finder files names changed to date and time? I don’t think you’ll find too many others enthusiastic for that!
  • Job Hopeful
    June 29, 2014 at 9:19 am
    Probably not, but it worked well for me. Way better than FCP7.
  • Marcus Moore
    June 30, 2014 at 2:04 pm
    If I could ask- how is this helpful for you?
  • Job Hopeful
    June 30, 2014 at 2:35 pm
    For the work I do it works well organizing all media by date as it mostly end up being sequential type movies, as in most of the clips end up in the order that they happened, and so if a second camera was covering the same subject I can dump all media in together in finder and as long as both camera’s were set to correct time clips should mostly all end up in the correct order.
    It also me to remember what came from where so if I have 20 different clients footage and I need to use clips out of various ones I am not ending up with lots of files named the same on the timeline.
    Hope I explained myself clearly enough.
