  • Oliver Peters
    January 31, 2012 at 11:02 pm
    [Cody Walters] “Does this mean you have the ability to export out an xml and import this into Color for color grading”
    FCP 7 and FCP X do not use the same version of XML and they are incompatible with each other. You have to use Assisted Editing’s Xto7 for Final Cut Pro to get back to Color. 7toX gets you from FCP 7 to FCP X. DaVinci Resolve will roundtrip between both versions of FCP.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Cody Walters
    January 31, 2012 at 11:10 pm
    Thanks. I’ll have to try out Resolve Lite then.
    Cody Walters
    JW Studio LLC
    Houston Video Production
    Houston Wedding Videographer
    Final Cut Studio 3
    Adobe CS5 Master Suite
    Panasonic HVX-200
    Canon 7D
  • Adam White
    January 31, 2012 at 11:28 pm
    All great stuff no doubt. Hope these updates keep improving the app for those who use it.
    I think the lack of a dedicated viewer is still a bummer. Particularly since multicam uses one – why not have an optional permanant viewer for those that want it? Its a bit of a mind block for me not having one. And there are still too many of those mind blocks for me to get on with X.
    Those design decisions I always hated are still there, so whatever happens this isn’t going to be the App for me. But I think its cool that its getting better for those that like it.
  • Michael Gissing
    January 31, 2012 at 11:32 pm
    I am beginning to see da Vinci as a lynch pin in getting FCPX projects graded and back into FCP7 for layout to tape. Just have to work out how to get titles over….
  • Michael Gissing
    January 31, 2012 at 11:55 pm
    Also curious if the old Automatic Duck FCPX to OMF software still works with this updated vers.
  • Craig Seeman
    January 31, 2012 at 11:56 pm
    I can’t see them having a “permanent” viewer (IMHO) but I could see, given what multicam is doing, having a gang function which creates a viewer. I think they’re more inclined to have it there when you use a feature that needs it and gets out of the way otherwise. Also right now you get the two up when trimming with the mouse but not when trimming with the keyboard. I’d think that’s something that might be added down the road as well.
  • Oliver Peters
    February 1, 2012 at 3:01 am
    I’ve done a bit of testing throughout the evening with the various features and, of everything, the Relink feature is HUGE for editing workflow. This finally permits offline-online workflows.
    Cut with low-res media files. Dupe the Project and then Relink media to the high-res files. You can have changed the clip name in the Event and when you Relink it asks for the original media file name instead of the changed name. That’s great. The only missing feature seems to be that there is no “match exact name”, so you have to hunt down the list and find the exact match. Once the first one is found, the rest will also be found.
    Clips for the relinked files will be imported into the Event, so if you are using this for offline-online, I recommend creating a new Event and associating the duped Project with that new Event as its default. Otherwise you’ll get duplicate clip names in the same Event.
    – Oliver
    Orlando, FL
  • Chris Harlan
    February 1, 2012 at 3:52 am
    [Oliver Peters] “I’ve done a bit of testing throughout the evening with the various features and, of everything, the Relink feature is HUGE for editing workflow. This finally permits offline-online workflows.
    So glad to hear that!
    [Oliver Peters] “Cut with low-res media files. Dupe the Project and then Relink media to the high-res files. You can have changed the clip name in the Event and when you Relink it asks for the original media file name instead of the changed name. That’s great. The only missing feature seems to be that there is no “match exact name”, so you have to hunt down the list and find the exact match. Once the first one is found, the rest will also be found.
    Clips for the relinked files will be imported into the Event, so if you are using this for offline-online, I recommend creating a new Event and associating the duped Project with that new Event as its default. Otherwise you’ll get duplicate clip names in the same Event.”
    That is huge. The ice is beginning to melt a bit. Thanks for reporting in!
  • Justin Schultz
    February 1, 2012 at 4:28 am
    Here here Ben. My issue with the discussion has never been a matter of content, but tone.
  • Steve Connor
    February 1, 2012 at 11:26 am
    Fabien Daguerre has also just pointed out on the techniques forum that there is now an autosave folder in the projects folder, this has timestamped versions of your projects as in FCP7, hopefully this means no more days worth of work lost for some people!
    Steve Connor
    “FCPX Agitator”
    Adrenalin Television
Page 5 of 7
