  • Andrew Richards
    January 31, 2012 at 5:31 pm
    [Gerrit Van Dyke] “I believe you still can’t export a proper XML from FCP X that can be opened in FCP 7, Avid or Premiere right? That seems to be one of the big ones. As someone who doesn’t use FCP X, I’m still concerned about working with outside suppliers for colour grading, online and audio.”
    Not from X itself, but there are now tools for going either direction.
    Xto7, $50 in the Mac App Store
    7toX, $10 in the Mac App Store
    Best,
    Andy
  • Craig Seeman
    January 31, 2012 at 5:55 pm
    I think what we’re seeing today is the “mood swing.” There’s still a lot missing, a lot that needs to be done. I think though people are feeling just a tad bit secure that the reintroduction of features will happen. It’s seeing things like Photoshop layers happening again and re-linking as well, one gets a sense that Apple will be putting things back in even if it takes a bit of time.
  • Warren Eig
    January 31, 2012 at 7:15 pm
  • Shane Ross
    January 31, 2012 at 9:13 pm
    [Warren Eig] “The no tracks is a big no no for me.”
    Me too. As is the lack of a Viewer, and the whole new editing paradigm in general. They changed something that didn’t need changing, and the new way makes no sense to me.
    Nice that they added these options for those who like it. But I can’t see myself using it. Although the new Multicam feature looks sweet, and I am jealous of it.
    Shane
    Little Frog Post
    Read my blog, Little Frog in High Def
  • Andy Neil
    January 31, 2012 at 9:16 pm
    [Shane Ross] “Nice that they added these options for those who like it. But I can’t see myself using it. Although the new Multicam feature looks sweet, and I am jealous of it.”
    I’m sorry you feel that way Shane. But you’re right about the multicam. It’s absolutely amazing. There’s only one thing it’s missing in my opinion, but that’s really more of a general note than one specifically related to multicam.
    Andy
    https://www.timesavertutorials.com
  • Neil Goodman
    January 31, 2012 at 10:08 pm
    the other main thing is the connected clips and slip slide behavior.. if that became override able so the connected clip doesn’t go along for the ride when slide editing, and a dedicated viewer, id probably give it a more serious look. hopefully in 10.4 ;0
    Neil Goodman: Editor of New Media Production – NBC/Universal
  • Oliver Peters
    January 31, 2012 at 10:28 pm
    FYI – a copy & paste from the release notes below.
    – Oliver
    ______________
    Final Cut Pro X version 10.0.3 adds the following features:
    Multicam editing with automatic sync and support for mixed formats, mixed frame rates, and up to 64 camera angles
    Advanced chroma keying with controls for color sampling and edge quality
    Media relink for manual reconnect of projects and Events to new media
    Ability to import and edit layered Photoshop graphics
    XML 1.1 with support for primary color grades, effect parameters, and audio keyframes
    Multiple improvements to the Color Board, including new key commands, editable numeric fields, and adjustable parameters that act like infinite sliders when dragged
    Ability to reorder color corrections in the Inspector
    Reveal in Event Browser shows clip range in the filmstrip while in List View
    Batch offset for clip date and time
    Ability to search text added to Favorite and Reject ranges
    Beta version of broadcast monitoring with third-party PCIe and Thunderbolt I/O devices
    Final Cut Pro X version 10.0.3 also improves overall stability and performance, and addresses the following issues:
    Improves performance when editing text in titles
    Improves performance when applying an effect from the Effect Browser
    Improves keyframing behavior in the Inspector, with keyframes automatically added when moving to a new point in time and adjusting a parameter
    Modifies transition behavior so that all newly added transitions use available media and maintain project length
    Fixes an issue which affected audio solo while skimming
    Resolves issues related to using Synchronize Clips with media containing a silent audio channel
    Fixes an issue in which constant speed retiming was not properly applied when using the Paste Effects command
    This update is recommended for all users of Final Cut Pro X
  • Cody Walters
    January 31, 2012 at 10:35 pm
    [Oliver Peters] “XML 1.1 with support for primary color grades, effect parameters, and audio keyframes”
    Does this mean you have the ability to export out an xml and import this into Color for color grading, and then re-importing the finshed xml back into FCPX? In other words, can I use Apple Color for color grading?
    Cody Walters
    JW Studio LLC
    Houston Video Production
    Houston Wedding Videographer
    Final Cut Studio 3
    Adobe CS5 Master Suite
    Panasonic HVX-200
    Canon 7D
  • Andy Neil
    January 31, 2012 at 10:38 pm
    Somehow I doubt it. Apple created a new XML for FCPX which means that it probably only works with programs that incorporate that. Since Color is EOL…
    Andy
  • Craig Seeman
    January 31, 2012 at 10:43 pm
    Use Resolve Lite. It’s free.
Page 4 of 7
