Activity › Forums › Adobe After Effects › 007 intro specific recreation
  • 007 intro specific recreation
    Posted by Oleg Plachkov on July 8, 2015 at 7:33 pm
    We all now the 007 Gunbarrel sequence, Bond walks while being tracked by a gunbarrel suddenly shoots it, blood begins to fall down, the barrel shakes and moves back and forth and then it turns into a white circle which opens into the movie. I have the gunbarrel comp and I want to add a video after it (the GB Sequence is my intro). How do I achieve that the circle opens directly into the video? If needed footage will be provided.
    Derek Boettcher replied 11 years, 2 months ago 2 Members · 1 Reply
  • Derek Boettcher
    July 9, 2015 at 4:30 pm
    Depending on how you work it you could also have the circle fade out to transparency or wipe out using either a shape layer+scale+alpha inverted track matte or a subtract circle mask+mask expansion over your precomp of your gun barrel sequence. Then just render it out as a .mov with a 32bit color space / RGB+A render settings, and lay that on top of your video sequence from your non-linear editor. Cheers.
    Best,
    Derek Boettcher
    Creative Management
    BTH Media Group
    https://bthmedia.com
