Activity › Forums › DaVinci Resolve › You don’t need a Davio and you don’t need an HD link – perfect REC 709 with just a consumer plasma
  • Anders Ballestad
    July 25, 2012 at 6:20 pm
    How do you deal with the fact that most consumer displays are adaptive / non-static these days? As an example: a white patch (RGB=(255, 255, 255)) will be displayed at different output luminances depending on the size of the patch; there are similar issues for chromaticities. A static 3DLUT correction will always correct to whatever test-pattern you used to measure the display, and won’t deal with variable content. Thanks.
  • Robert Ruffo
    July 26, 2012 at 1:19 am
    Not all displays float white nor black much at all. In the case of a VT25 (with last firmware), VT30 or VT50, the amount is tiny, and perceptually pretty much invisible.
    Some other consumer displays do this way too much, and, you are right, should not be used for grading.
  • Mike Lary
    July 26, 2012 at 2:04 am
    “How do you deal with the fact that most consumer displays are adaptive / non-static these days? As an example: a white patch (RGB=(255, 255, 255)) will be displayed at different output luminances depending on the size of the patch; there are similar issues for chromaticities.”
    You need to disable any adaptive / “smart” settings on your display before calibration. That’s standard operating procedure when calibrating any device.
    Mike Lary
    Digital Factory
    Seoul, South Korea
Page 3 of 3
