Activity Forums DaVinci Resolve XYZ Conversion
  • Suny Behar
    November 19, 2012 at 8:11 pm
    Hi Oyvind,
    That link you posted with the LUT seems to no longer be active, can you post it again?
    Suny
  • Alex Coppedge
    August 16, 2013 at 6:41 pm
    Hi Oyvind, the Rec709 to DCI XYZ is no longer active. Would you mind reposting the link? I’m using Doremi Cine Export to make DCPs and the white levels and gamma seem to be shifting and want to try out your LUT.
  • Dori Bashan
    February 20, 2014 at 7:27 pm
    Hi all
    If someone have the Cinecube DCI_XYZ.xml file and can share it with me it would be very helpful
  • Sebastiano Greco
    December 18, 2014 at 10:44 am
    Hi! I’m so curious to try your Rec709–>DCI with Gamma conversion LUT, but unfortunately the link has expired. Could you send it to me to seby.greco@gmail.com? I will appreciate that very much! Thank you and all the best!
    Sebastiano
Page 2 of 2
