Activity Forums Adobe Premiere Pro xml issue Premiere to FCP7
  • Lewis Stiefel
    April 25, 2013 at 2:51 pm
    Hey Tim
    All sequences from same footage….clips r different in that one sequence though. I just recut
    in FCP…not a big deal….though strange….I don’t go from PP to FCP very often…I am however
    beginning to transition to PP but since I have your expert advice to tap in to a few questions on
    PP…..Why is it that when you go from list view to icon view shots r not in same order? I have FX
    Factory Pro and use their transitions a lot …current pp cant just drop in those transitions like
    in FCP ….will Adobe be addressing this? When is CS7 officially being released? Thanks again for your time.
    Best
    Lew
  • Tim Kolb
    April 25, 2013 at 8:44 pm
    The icon/list view switch blows the order…Adobe knows it…they’ve been hearing about it a lot. I don’t know if you’ll see anything this next drop, but Adobe has been listening pretty intently lately (and like many things prior to release with non-disclosure agreements, etc…those who tell don’t know and those who know can’t tell…release date is in Adobe’s hands).
    I’d need a bit more detail on the “transition like FCP” thing. You should be able to just drop it on the edge of a clip or an edit and it should grab…
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Lewis Stiefel
    April 26, 2013 at 5:50 pm
    Hey Tim
    What I meant on the FX factory transitions is that in FCP you can just drag the effect between
    2 clips and u have your trans….in PP you have to keyframe the trans….very cumbersome
    and time consuming. Only FilmImpact trans work the way they should.
  • Tim Kolb
    April 26, 2013 at 5:59 pm
    Hmmm… do they have presets of some kind that don’t load into Premiere Pro? If they’re a transition, isn’t the default to just execute the change over the frame length of the transition?
    …sorry, I think I’m missing something here. (But I’m not familiar with FX Factory transitions.)
    TimK,
    Kolb Productions,
Page 2 of 2
