Activity › Forums › Apple Final Cut Pro › XML based app to import subtitles into FCPX
  • Joseph Devenney
    March 13, 2017 at 2:36 pm
    Hi all,
    I am trying to import subtitles into FCPX 10.2.3. I am using XTI 1.8.5.1 to convert my “.stl” into a “FCPXML” file that I can import into my Library. I exported an FCPXML file containing only an empty text generator and using this, successfully converted the “.stl” file into a FCPXML file.
    The problem is that FCPX will not import the new FCPXML file.
    It comes up with the following error.
    “DTD validation failed. (ID ts 1 already defined)”
    After this I tried importing the FCPXML into DavinciResolve and it did import, although the text did not have a subtitle box and was placed in the middle of the screed rather than the lower third.
    If anyone could help me figure out where I went wrong or how I can fix the FCPXML, it would be much appriciated.
    Thank you,
    Joseph
Page 2 of 2
