Activity › Forums › Sony Cameras › XDCAM Transfer only shows proxies
Daniel Wright replied 15 years, 11 months ago 4 Members · 11 Replies
Daniel Wright
October 9, 2010 at 10:12 pmSorry to be late to the party.
As Ian says, the files you have will be unusable in Vegas, for example, but I believe XDCAM Transfer should be able to stitch these files back together provided you have *all* the files and they reside in a directory structure that *exactly* replicates a disc.
So, if you are still waiting for the original discs or replacement copies, you could try recreating the structure below, and add the ‘My_Disc’ (or whatever you want to call it) folder to XDCAM Transfer. You need a folder containing a folder called PROAV which contains all the files you were given, I suspect.
/My_Disc
—-/PROAV
——–/index.xml
——–/CLPR
——–/Sub
——–…If you need the reconstituted MXF files, XDCAM Transfer has an option in the clip’s context menu to copy clips to file. The resulting file is a single MXF file created from all the components that Ian mentions.
HTH
