Activity Forums Sony Cameras XDCAM Transfer 2.1
  • Job Van nuenen
    January 9, 2008 at 7:59 am
    Hi Mark,
    The trick is to import the folder ‘above’ the BPAV. that is: the folder you’ve copied the BPAV folder into. This way XDcam transfer is thinking it’s importing a ‘mount’ wich is similar to importing directly from the SxS card.
    I don’t even have the EX1 or the card around at the moment 🙂 (I did a test with a rental camera, mine is still in backorder.) and I’ve just tried it with my copied footage, works fine.
    Hope this helps you out!
    Job
    Media100/after-effects/Combustion/FCP/Flint/Flame/Inferno..
    Thank heavens; there’s a sign of progress here..
  • Bob Glover
    January 9, 2008 at 10:42 am
    Thanks Job,
    I followed your instructions and all worked fine.
    Thnanks very much.
    All the best
    bob
  • Mark Palmos
    January 9, 2008 at 10:48 am
    Yep, importing the folder which contains the BPAV folder works! great, which means one does not need a Mac to copy BPAV folders while on location… good news for modern man!
    Thanks Job
    Tot siens (?)
    Mark.
  • Michael Lorushe
    April 1, 2008 at 12:34 pm
    Hi Mark,
    I have a similar problem. I rented an EX1 and copied the files (BPAV and all) to my hard drive. When I use the XDCAM transfer software the videos appear but comes up as ‘no media’. The XDCAM clip browser reads the file fine. Is the only way to get XDCAM transfer software to properly see my video is to transfer the BPAV files back onto an SxS card?
    Thanks, Myles
  • Mark Palmos
    April 1, 2008 at 3:36 pm
    Hi there Myles
    Actually the problem is sorted for me.
    If you put the BPAV folder INSIDE ANOTHER folder, then get the transfer
    utility to “see” that new folder, it will recognize the footage inside the
    BPAV folder inside it.
    Mark.
  • Michael Palmer
    April 1, 2008 at 3:49 pm
    You may also want to download the latest 2.5.1. XD Cam transfer program that fixes the Clock timecode issue with the EX1.
    https://bssc.sel.sony.com/BroadcastandBusiness/markets/10014/xdcamDownload.shtml
    Good Luck
    Michael Palmer
Page 2 of 2
