Activity Forums Apple Final Cut Pro X2Pro file size too large
  • Glenn Payne
    May 3, 2019 at 3:06 am
    Yeah. That’s what I’m thinking as well. I thought it was because I had the video in the timeline still. But when I removed it the file size stayed the same.
    Thanks again for trying to help! Maybe someone else will stumble upon this thread and have some advice.
  • Glenn Payne
    May 8, 2019 at 2:22 am
    Slight Update:
    I went through the entire film and narrowed down the different roles. Ended up with 7 total. When I render out the AAf from the XML with just the roles I’ve chosen to use the AAF file barely shrinks. It goes from 5.58 to 5.45gb. ☹
    Still not sure why it’s so massive. Any other ideas from any of you guys?
    Thanks for any guesses.
  • Scott Saracen
    April 30, 2020 at 9:11 pm
    Hey Glenn,
    I know it has been just about a year, but wondering if you ever solved this problem? I am having the same issue. 2 minute test has yielded me a 5.57GB file. I stripped video and only slightly smaller size.
    Thanks for any insight.
    Scott
  • Glenn Payne
    May 1, 2020 at 1:39 am
    Hey Scott,
    I’ve been racking my brain all day since I saw your post. I also checked with my post sound guy and I don’t think I ever found a real solution. I think we just did the best we could with a huge file. All the suggestions above were solid and should have worked, if you want to try those. It was a strange problem.
  • Scott Saracen
    May 1, 2020 at 2:01 pm
    Thanks for your reply Glenn.
    I was going over and over everything last night…quadruple checked my preferences…handles were at 2 seconds. Then my eye caught the main screen, the option “trim embedded audio”. I checked that, exported an AAF and it was 50MB…I could have kicked myself for all the time I wasted…ugh!
  • Glenn Payne
    May 1, 2020 at 10:28 pm
    That’s great though! At least you figured it out. It basically felt like that was happening with me but for some reason it wasn’t using just the trimmed parts when I told it to. Who knows…
Page 2 of 2
