Activity › Forums › Apple Final Cut Pro › X native support for Braw?
  • Robin S. kurz
    July 19, 2022 at 11:59 am
    First off, BRAW is most certainly not competition to ProRes RAW, since BRAW, unlike ProRes RAW, is by definition not even RAW to begin with. So Apple couldn’t care less if it ran on FCP. Otherwise, by that logic, why would they support any and every other (relevant) RAW format?
    Secondly, it is entirely up to BMD to work with Apple to get BRAW working in FCP, as it has been for every other “RAW” vendor. So if it’s not working, BMD has chosen to not have it work. And having been there at the release of both, I can only say that, for me, it seems apparent that Grant Petty is staying true to his name after Apple unexpectedly stole all their thunder with the announcement of PRRAW just a few weeks prior to their announcement of BRAW. Top that off with a partnership and exclusive deal with their arch-rival AtomOS… boom. Yes, all of which also explains their refusal to support PRRAW in Resolve as well. So it’s quite the two- and not one-way street.
    And sure, the fact that PRRAW is superior in both quality as well as in performance doesn’t exactly make it a high priority for BMD who is trying to establish BRAW as the go-to tie-in codec for their users. What’s more effective than not caring about what the user needs, but rather just dictating it to them? Clever.
    I see certain parallels with Adobe. Jump ship there, and you immediately lose any and all access to your own intellectual property. Scary.
    And no, it most certainly is not a matter of expense seeing that licensing ProRes is absolutely FREE (and something they already have for every other flavor of ProRes btw… it’s all one license). You merely have to subject yourself to Apple’s arduous, lengthy QC process to get approved/certified. As many much much smaller companies have done btw. Some that don’t even have a Mac version of the respective app!
    AV Foundation, for safety/stability reasons, also does not have the plugin/extension framework/SDK that Quicktime had, which is why not just anybody can simply use the BRAW (or any other random) SDK to write a plugin in the meantime (for money, as others did for PPro).
    Ergo: upset and frustrated? Talk to BMD about it. Unless someone has factual information to the contrary that I’m not privy to that points to anything else?
  • Craig Seeman
    July 19, 2022 at 3:14 pm
    I’ve heard similar analysis to Robin’s elsewhere as well.
    The problem is the end user still has to make a difficult workflow decision.
    As far as the post production market is concerned one might has how many Blackmagic BRAW users are there vs ATMOS with ProResRAW users. Few people have the choice between both codecs so hardware (BMD Cameras vs other camera with ATMOS) is going to dictate the choice.
    While it’s only anecdotal I hear more about FCP users moving to Resolve than the other way around. I don’t doubt that’s added by BMD including the full version of Resolve free with the camera. That may mean BMD will win this war by attrition.
  • Mark Smith
    July 19, 2022 at 5:41 pm
    I’ve long thought that the BMD pocket cameras were the gateway drug to Resolve, you get a camera with a lot of bang for the buck and a free pass to Resolve which is a way to siphon people out of the FCP or Premiere world. I have Resolve, but rarely use it, FCP just suits me better, though I have to say Resolve is quite a package.
  • Joe Marler
    July 19, 2022 at 8:57 pm
    If it’s any consolation you can transcode BRAW to ProRes using EditReady, which also can transcode REDRAW, Canon Cinema RAW Lite and ARRIRAW to ProRes: https://hedge.video/editready
  • Craig Seeman
    July 19, 2022 at 9:02 pm
    There’s also a plugin for FCP from the Color Finale developers that transcodes from BRAW to ProRes. The problem is that takes time and means creating another large file. Also one can import into Resolve (which is free after all) and then export to ProRes. All this is a lot of extra work.
  • Robin S. kurz
    July 20, 2022 at 10:49 am
    Just on a side-note: this new forum is an absolute UX nightmare. Nothing appears to work as it, I assume, is supposed to. 🙄
    I personally think that’s hyperbole. Because I have several BMD cameras and there is still absolutely no chance that I could switch to Resole or any track-based NLE for that matter just because of that of all things. Ever. But then I avoid shooting BRAW if and when possible anyway, since I can’t see a single advantage to shooting with it outside of some very specific and rare (lighting) exceptions, considering the workflow alone. I’d even go so far as to say that the vast majority only shoot in BRAW because they either bought into it somehow being “the thing” to shoot in—without knowing the first thing about how to process it in a way that even uses any possible advantage—or, as in my case, because BMD cleverly and inexplicably made it so you have to shoot BRAW with certain resolutions/settings. Which is clearly just a ploy. In which case, big whoop. I can run everything through Resolve in minutes or use the aforementioned plugin. 🤷🏼‍♂️
    But obviously native is always preferred. So I hope BMD—i.e. certain people there—get off their high horse at some point and make it happen. We’ll see.
    What one can say is that PRRAW has been adapted/is supported by multiples of OEMs that have come to support BRAW. Again, IMHO, for good reason. The range of cameras and manufacturers that support recording PRRAW is also extensive in comparison, whose joint market share is multiples of BMD’s. Software support on the other hand is pretty much equal I would say.
    I would also far more trust the implementation/support of someone that had to go through rigorous QC with the developer of the codec first than some rando that got his/her hands on the SDK. Speaking of which, let’s also be very clear that BRAW is most certainly not open source.
    No, need does. And how many people actually and factually need RAW, no matter the flavor? Sure, a vast crowd has blindly bought into the “RAW” buzzword and now acts as if anything else is suddenly blasphemy and beneath them. If those people want to switch based solely on those false pretenses… er, ok. 👍🏼
    That’s truly anecdotal, yes.
    The difference between it and the free version being yet another something that only few even understand or factually benefit from. Or what is it that is specific to the “Studio” version that you think draws all these anecdotal people that they just can’t do without? To the extent that they’ll just upend their entire workflow willy-nilly?
    I think you vastly overestimate the power and relevance of a codec and especially its market share. Resolve will “win” just for being an exponentially better Premiere Pro, period. You either, like me, understand the far superior trackless paradigm and will never return, or you don’t. And in the case of the latter you are far better off using Resolve than PPro as your NLE, that’s for sure. That’s the only real and relevant realization I think people will come to more and more.
  • Craig Seeman
    July 20, 2022 at 12:24 pm
    That may well be the issue/game that BMD plays. Really for most work, even broadcast work Apple ProRes HQ may be all that’s needed. Only in the most demanding feature film or high-end advertising would RAW (and BRAW isn’t quite raw) have notable advantages.
    Alas BMD cameras have a growing base given their low point of entry. It’s as if BMD uses BRAW specifically to frustrate FCP users by slowing down the workflow with transcodes and adding to storage costs. Now they’ve thrown in gyro stabilization which is only supported in Resolve.
    All this does seem to make Sony “cinema” cameras more attractive with their 422 10-bit I with flexible autofocus and IBIS (and ProRes RAW with Atmos if you really need it).
    BTW I hate track-based editing and I say that with experience going back to the earliest Avid around 1990 or so. You can throw in all the bells and whistles in an NLE but nothing beats the magnetic timeline and organizing tools in FCP for speed, efficiency, and flexibility.
    Now if only there were a way more cameras could record ProRes RAW internally (I suspect the RED patents stand in the way).
  • Mark Smith
    July 20, 2022 at 12:58 pm
    I have both color finale and CFT transcoder – I like them and use them both .
  • Mark Smith
    July 20, 2022 at 1:08 pm
    I agree that it might be the situation that BMD uses Braw to purposely frustrate FCP users. Also agree about track based editing, my editing experience is just better with FCP because I feel like its tilted towards facilitating creative editing process, aside from having great organizing tools. I’m not going back to track based editing anytime soon. Stability and speed of FCP on my M1 mac mini is another huge plus. I’ve had very few issues, the software and hardware combo just works, allowing me to focus on the edit.
  • Robin S. kurz
    July 20, 2022 at 1:32 pm
    Why even HQ? I’ve never gone beyond 422 and more often than not even shot in mere LT and have yet to hear of any complaints.
    BTW, when shooting with cameras that do PRRAW (to my AtomOS, obviously) I will in fact shoot in it. Not because I think I need it, but seeing that I would otherwise shoot in ProRes anyway, and I’m not getting hit either in terms of size or performance… why not? Basically getting HQ for the price of 422. 😉
    But even then… color depth, etc. are all the same. You merely have a few options more should you have cocked something up in-camera. Other than that I dare anyone to point to an actual, perceptual difference in the final (non-cocked) product.
    True. I’m the first to admit that price was at the top of my list of reasons for purchase, not because I thought they were otherwise above and beyond the competition. Because they’re not.
    But then… not being a public company I honestly question how well that whole strategy is going for them and will continue to. Because looking at the level of development compared to pricing… from “oddly cheap” to FREE… I have to wonder how long that can last. 🤔 Not even Apple is that brazen, and they can afford it!! 😄
    Well, storage cost really isn’t the largest factor. What is it? A fraction of a cent per GB? But on the other hand, my transcoded files aren’t larger and the originals are deleted, so… 🤷🏼‍♂️
    That I haven’t looked into, so I have no idea what I’m missing, if anything. But sure, much like Apple they are smart enough to leverage their power over everything in their ecosystem to their advantage! I, too, would love the multicams that an ATEM ISO generates on the fly for Resolve for FC as well for example. But, oh well…
    100% +1, yes. I started with Premiere 1.0 after having sat at an Avid first, then moved to Media100 and an occasional Avid again, then FC pretty much exclusively ever since v1.25.
    It is the (absolutely ludicrous IMHO) RED patent and only the patent, yes. Ironically also the exact same reason why BRAW is what it is: fake. Otherwise, they would have gotten pounded by RED, too. As well as why they suddenly removed recording cDNG on their cameras as well (of course… zero loss there).
    If only Apple’s lawyers hadn’t IMHO cocked up the challenge against that stupid patent… this way we have to wait until 2028! 🤦🏼‍♂️
Page 2 of 4
