Activity › Forums › Adobe After Effects › Workflow confusion.. markers between comps and precomps?
Roei Tzoref replied 9 years, 10 months ago 5 Members · 13 Replies
Roei Tzoref
November 5, 2016 at 9:57 pmhere is a similar example to what you have. I have a precomp inside 2 comps. the precomp has 3 comp markers like this:
I go back one comp to the master comp and set a dummy marker on my precomp like this:
and I choose update markers
now I have this
Roei Tzoref
After Effects Artist & Instructor
♫ Ae Blues Tutorials -
Jaqai Mickelsen
November 5, 2016 at 10:03 pmAaaaha.
So, I figured out why that option was grayed out for me. Because I was foolishly adding a layer marker to a pre-comp in “main comp” that didn’t have any markers within it. So, there were no markers to update.
It doesn’t work for all the pre-comps in the master, just the one you’re specifically working with.
But, just as you outline above, once I put the dummy it on the correct pre-comp, that “update markers…” was available in the context menu and works as you described.
Thanks for taking the time!
Roei Tzoref
November 5, 2016 at 10:05 pm
