Activity › Forums › Adobe After Effects Expressions › whole number slider
whole number slider
Posted by Ben Wolfinsohn on November 1, 2012 at 6:58 amI am new to expressions and sliders – is it possible to create a slider that only works with whole numbers, no decimals?
Ian Brown replied 2 years, 6 months ago 6 Members · 19 Replies -
Jamie Bradshaw
November 1, 2012 at 1:32 pmcopy the following expression into your Slider:
Math.floor(value);
Math.floor rounds down whatever number is inside the bracket.
I hope this helps.
JimJam•Graphics
https://www.jimjamgraphics.com/ -
Darby Edelen
November 1, 2012 at 3:14 pm[Jamie Bradshaw] “Math.floor(value);
Math.floor rounds down whatever number is inside the bracket.”
There’s also:
Math.round()Rounds to the nearest number, Math.round(0.5) returns 1, Math.round(0.4) returns 0 for example
Math.ceil()Returns next highest whole number, Math.ceil(0.0001) returns 1 for example
And to complete the picture:
Math.floor()Returns next lowest whole number, Math.floor(1.9) returns 1 for example
Darby Edelen
Ben Wolfinsohn
November 1, 2012 at 4:29 pmsorry, this is the first slider and expression i’ve ever made, where do i paste that exactly?
thanks! -
Darby Edelen
November 1, 2012 at 5:36 pm[ben wolfinsohn] “sorry, this is the first slider and expression i’ve ever made, where do i paste that exactly?
thanks!”That depends. If you just want to take the slider value and round it then your entire expression (applied to the slider property) might look like this:
Math.round(value);You could use floor() or ceil() alternatively.
Darby Edelen
Ben Wolfinsohn
November 12, 2012 at 11:02 pmI’m still seeing the decimal point in the slider bar. is there no way to remove that then?
Dan Ebberts
November 13, 2012 at 12:32 amIf you’re using a text layer, you could use a source text expression like this:
s = effect(“Slider Control”)(“Slider”).value;
s.toFixed(0)Dan
Ben Wolfinsohn
November 13, 2012 at 1:04 amsorry, i’m a bit confused. let me try to explain.
I have 3 comps, each comp is time remaped, each remap has an expression like this –
comp(“head contol”).layer(“head contols view 1”).effect(“head turn (18)(1-forward)”)(“Slider”)/23.976and all 3 of the comps are pointing to the same slider.
so where would i put the code you’re talking about? and would I put it in all 3 comps?
Dan Ebberts
November 13, 2012 at 1:58 amNow I’m confused. If you’re not displaying the value, why do you care about the decimal point?
Is it that you have the rounding expression applied to the slider, but when you divide that value by 23.976 you don’t get a whole number? How about something like this instead:
framesToTime(comp(“head contol”).layer(“head contols view 1”).effect(“head turn (18)(1-forward)”)(“Slider”).value)
Dan
Ben Wolfinsohn
November 13, 2012 at 2:44 amthat didn’t seem to do it.
basically i have a comp with 18 frames, each frame has a drawing of a different perspective of a head. with the slider i can easily scroll through the different faces when i use it with timeremaping. the slider goes from 0-17. BUT, I don’t need the slider to display 1.3 for an example, cuz i don’t have .3 of a frame. i only need it to show numbers 0-17 in the slider bar.
does that make sense? is it possible?
Dan Ebberts
November 13, 2012 at 3:22 amIf you put the Math.floor(value) expression on the slider, you’ll get 0.00, 1.00, etc., but I don’t think there’s any way to get rid of the “.00” part, if that’s what you’re asking.
Dan
