Danny Hays
September 17, 2010 at 7:55 pmSome people use different color temperature lights to get like possibly a warmer look in the skin tone for like keying someone in an late afternoon out door scene, or a cooler look to key someone in a winter scene. I would think a variety set of white balance cards cards could be used in the same way. Checkout this link on white balancing.
https://www.cambridgeincolour.com/tutorials/white-balance.htmHope this helps, Danny Hays
Stephen Mann
September 18, 2010 at 3:12 amFor white balance, white and gray are the same.
Steve Mann
MannMade Digital Video
http://www.mmdv.com -
Danny Hays
September 18, 2010 at 3:43 amSo your saying it makes no difference white balancing with a grey card? At some point it wont work for white balancing. Try doing it with a black card.
Stephen Mann
September 18, 2010 at 2:47 pmIn theory, you could white balance on a black card. All that’s required is a neutral card. 255,255,255 is just as neutral as 128,128,128 – and the camera doesn’t care because to white balance, all the camera wants to do is make the RGB levels equal – thus “Balanced”.
Steve Mann
Danny Hays
September 19, 2010 at 4:54 amI’ll have to try that. Finding a real or close to, black object to set to could make things easier, in a pinch when there’s not a real white surface to use. Have you tried this?
Matt Crowley
September 19, 2010 at 10:10 amA dark grey or near-black object would theoretically allow white-balance to be set (because there’s no hue to it), but the camera will have a harder job forming a decent noise-free picture on a dark object. Matt bright white would be best, particularly if the available light is dim, or a light neutral grey.
Bob Peterson
September 20, 2010 at 12:56 pmI have my assistant hold the white board at the speaker’s position. First, I focus on the assistant’s face and then turn off auto focus. The assistant then holds up the white board, and I perform the white balance adjustment. That procedure is intended to insure that the camera has the white board in focus.
Gilles Gagnon
September 20, 2010 at 1:27 pmThanks Bob,
I like the idea of focusing on the subject’s face. I’ve found it difficult to focus on the my “current” small white card, with no reference to focus on except… snow white.
Gilles
Norman Willis
January 10, 2011 at 2:07 amHi Steve.
I appreciate your knowledge and expertise.
If white is the same as grey, then why do pro photographers use grey?
Actually, maybe I should start a new thread, since this one is kind of old? (Or is that not preferable?)
Norman Willis
January 10, 2011 at 3:35 amSorry, I don’t mean to ask stupid questions. Maybe it is just because there are so many different ‘colors’ of white…and maybe they can make grey more uniform?
I guess I should just get a grey card and experiment.
Norman Willis
http://www.nazareneisrael.org
