Activity Forums VEGAS Pro Which version to buy
  • Harold Brown
    September 1, 2008 at 7:38 pm
    I use Vegas Pro 8 and do all of my compositing work there. I use a lot of stuff from Detonation Films in my movies and they look good. Here is a composite that I added to a Magic Lecture Promo. If you follow this link the video will start to play right away. It is about 15 seconds into the video. https://www.edellismagic.com/MultiMedia.html
    It is done with Vegas and a special effect from DF (https://www.detonationfilms.com/).
    Harold
    You can see that I added the effect as well as highlighted the background as the spark travels to the floor. All the sound is from the Sound Effects series from Digital Juice.
    __________________
    http://www.BhagaVideo.com
    Check out my published DVDs at
    http://www.edellismagic.com/Previews.html
  • Terry Esslinger
    September 1, 2008 at 11:16 pm
    If you are going to do compositing you will almost have to use Vegas Pro. The Studio versions are limitted to 4 video tracks. Vegas Pro has as many as you want.
  • Jesse Davenport
    September 2, 2008 at 5:29 am
    With Essentials, don’t you do the special effects in the program? If that’s the case, can I put the video back into Vegas Pro?
  • John Rofrano
    September 2, 2008 at 11:37 am
    Yes, Vegas Pro is quite capable of compositing the Action Essentials video with your original footage. You won’t need anything else.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jesse Davenport
    September 3, 2008 at 10:15 am
    So which one should I get Essentials or EffectsLab Pro?
  • John Rofrano
    September 3, 2008 at 10:43 am
    Only you can answer that. If you just want pre-made overlays get Essentials. If you want to make your own, get EffectsLab Pro. Personally, given the choice, I would buy EffectsLab Pro.
    Don’t forget there is a free demo of EffectsLab Pro so you can download it and try it out before you buy. I’m a big believer in try-before-you-buy. This way there are no surprises.
    ~jr
  • Jesse Davenport
    September 19, 2008 at 8:57 pm
    I tried the Effectslab Pro demo and decided that I want to get Action Movie Essentials instead. Does anyone know how you get the special effects off the DVD?
  • John Rofrano
    September 20, 2008 at 12:13 pm
    I’ve never seen an Action Movie Essentials DVD but I would imagine that they are just video files that you drag and drop into your projects? Do you have the DVD? What’s on it?
    ~jr
  • Adam Rose esq.
    September 20, 2008 at 12:29 pm
    drop them on to new track above your main video
    right click and choose PROPERTIES. Find the alpha channel property and try dirty/premultiplied etc, i.e. change it from NONE
    resize to fit using either PAN / CROP or Track Motion or both.
  • Jesse Davenport
    September 20, 2008 at 8:55 pm
    I know how to put the effects in the video, but how do you pull them off the DVD?
Page 2 of 3
