Activity › Forums › Apple Final Cut Pro Legacy › Which still format will render quickest?
Chris Poisson replied 19 years, 4 months ago 5 Members · 15 Replies
Jerry Hofmann
May 13, 2007 at 1:24 pmTiffs render faster than JPEGs…
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Jerry Hofmann
May 13, 2007 at 1:26 pmI find that using this dpi instead of the more common 300 dpi also renders faster, and looks much the same… if you need to move or zoom on them, just make them larger than the frame size you’re editing them into. But keep them at 72dpi in Photoshop.
Jerry
Chris Poisson
May 13, 2007 at 2:20 pmHi Jerry, By my little tests tiffs and jpegs were almost a dead heat.
Jerry Hofmann
May 13, 2007 at 3:30 pmHave you tried lowering the dpi?
Boy I sure seem to feel that the tiffs here render faster… ?
Jerry
Chris Poisson
May 14, 2007 at 12:52 pmHi Jerry,
The control specs in my test followed the general recommended recipe around here, all the stills were 72 dpi at about 2 x the frame size, or 1440×960. All were made exactly the same from the same photos. I wish what you are saying was true, that’s what I suspected that got this whole topic going, that jpegs were slowing down a recent project, but it just ain’t true.
Sorry…
