Activity › Forums › Adobe Premiere Pro › Where can I find Premiere Pro 2014
Walter Biscardi replied 10 years, 10 months ago 6 Members · 15 Replies
Walter Biscardi
October 25, 2015 at 6:24 pm[Gary Childress] “I did find the install as everybody mentioned. But now I have a wierd problem where PP2014 says that the projects were created in a newer version and can’t be opened. Yet in PP2015 the same projects will open with the created in a prior version error and they must be converted.”
You can’t take a project backwards in versions. You need to make an XML from CC2015 and then open that in CC2014.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author, Chef.
HD Post and Production
Biscardi Creative MediaCraft and Career Advice & Training from real Working Creative Professionals
Ann Bens
October 25, 2015 at 6:33 pmXML means you are left with just the edits and some transitions.
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional -
Andrew Kimery
October 25, 2015 at 6:52 pm[Gary Childress] “I did find the install as everybody mentioned. But now I have a wierd problem where PP2014 says that the projects were created in a newer version and can’t be opened. Yet in PP2015 the same projects will open with the created in a prior version error and they must be converted.
Any ideas?”
I’ve heard about this error occasionally (same version used but you get the ‘newer version’ message) but never encountered it myself (at least not with PPro, I happened to me more than once with the old FCP). Try creating a new project in in 2014 and then using the Media Browser to import the project you want to work on. I’ve had a couple of PPro projects get corrupt and I’ve used this method to generate a ‘clean slate’ so to speak.
Walter Biscardi
October 26, 2015 at 12:17 am[Ann Bens] “XML means you are left with just the edits and some transitions.”
Not when it’s Premiere Pro to Premiere Pro. Everything comes across just fine. At least in my experience.
Going between NLEs things get lost in translation, but when just moving from a Premiere version to Premiere version, everything comes across just fine.
