Activity Forums Apple Final Cut Pro Legacy Weird little playback bug
  • Matthew Brodet
    October 29, 2009 at 7:35 pm
    A bit new here. where is the disc icon to up load the file?
  • Jeremy Garchow
    October 29, 2009 at 7:47 pm
    Right above where you type in your response.
    Jeremy
  • Richard Andresano
    October 29, 2009 at 10:57 pm
    Would love to have that desktopvideoout.component file. Were you able to upload? thanks,
  • Jeffrey Reid
    October 29, 2009 at 11:46 pm
    Yes! Thanks indeed. I was beginning to pull my hair out. I’m trying to get my hands on the file as well, but if you could post it that’d be great!!
  • Nick Meyers
    October 30, 2009 at 12:01 am
    hey, Matthew,
    great work on finding the fix to this.
    i’d LOVE to get that file,
    but cant find your email address.
    did you get a chance to upload it?
    otherwise MY email is nickm@bigpond.net.au
    thanks heaps!
    nick
  • Nick Meyers
    October 30, 2009 at 12:34 am
    I managed to get to that file on the FCP7 install disc.
    here’s what to do:
    Load up your Final Cut Studio Install disk,
    or if you’ve made a disk image (good idea) access that.
    Inside that, notice that the “Instal Final Cut Studio” package is actually an Alias,
    so right-click on that and “Show Original”
    You’ll be taken to a folder called “Installer” inside of which is another folder called “Packages”
    Inside the Packages folder locate the VideoOutSupport.pkg,
    right-click on it, and “Show Package Contents”
    Inside the Contents folder, locate the Archive.paz.gz file.
    Drag it to the desktop, and double click on it to un-zip it.
    This will create a folder called “Library”
    Open it, go to the QuickTime folder inside it,
    and there you will find the file “DesktopVideoout.component”
    Put this file in Macintosh HD > Library >QuickTime,
    replacing the similarly named file there.
    Digital Cinema Desktop Preview should now work.
    cheers,
    nick
  • Nick Meyers
    October 30, 2009 at 1:43 am
    i just got a new Software Update notification:
    “Pro Applications Update 2009-01 addresses general compatibility issues, improves overall stability, and addresses a number of other minor issues. This update is recommended for all users of Final Cut Studio, Final Cut Server, and Logic Studio.”
    it’s relatively small,
    i downloaded only and had a look,
    sure enough, there is a new VideoOutSupport.pkg in there.
    i’m pretty sure this is the official fix.
    nick
  • Michael Black fcp
    October 30, 2009 at 1:44 am
    is that an update to the update?
  • Nick Meyers
    October 30, 2009 at 2:04 am
    i’m guessing it is,
    but i’m not 100% sure.
    maybe i’m getting the original update again because i changed the file over?
    (thats why i didn’t install it)
    is anyone else getting the update?
    nick
  • Nick Meyers
    October 30, 2009 at 2:29 am
    Nick Meyers wrote:
    i’m guessing it is, but i’m not 100% sure.
    Nick Meyers now writes:
    well i installed it, and Desktop Preview BROKE again!
    i quite FCP, ran software update again, and got the all clear.
    then replaced the DesktopVideoout.component again,
    Desktop Preview now works again.
    and now when i run Software Update, i get the “Pro Applications Update 2009-01” notification again!
    so i’m leaving it alone now.
    nick
Page 3 of 7
