Activity Forums Adobe After Effects Weird Interlacey problem
  • Steve Roberts
    July 13, 2006 at 5:38 pm
    [Footbaggin] “Just out of curiosity, do you have any idea if this strobing effect could be a result of removing the pulldown at 30fps?”
    If the footage was shot on film and transferred to video, and you removed pulldown and dragged into a 23.976 fps comp, then rendered at 29.97 fps with pulldown added back in, you’d have no problems. Other than that, I’m not sure how to answer your question.
    [Footbaggin] “What should happen to the video if you do what I’ve done and Remove Pulldown when you don’t need to?”
    Then you’d have a 23.976 fps clip running in a 29.97 fps comp. Some of the frames of the footage will be repeated, some will not. It’s generally not a good thing to do.
  • Matt Wafaie
    July 13, 2006 at 5:43 pm
    That makes perfect sense. Thanks. That could very much explain why some of the camera movements appear to STROBE. Thanks for the info.
    M@
  • Steve Roberts
    July 13, 2006 at 5:56 pm
    No worries. You might want to invest in the Creating Motion Graphics books by Trish and Chris Meyer. Good info.
Page 2 of 2
