Wedding DVD burning file size Vegas Render
Graham Bernard replied 8 years, 7 months ago 6 Members · 22 Replies
John Rofrano
January 10, 2018 at 10:10 pm[Derek Charles] “How are these people able to have significantly lower file sizes and I dont see a quality problem?”
It all depends on the source video. Is it well lit? Is the camera locked down? Lots of motion or noise in the video will result in a lower quality render. There are a lot of factors to consider that affect encoding.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com -
Graham Bernard
January 11, 2018 at 5:33 am[John Rofrano] “It all depends on the source video.”
Agreed John. I posted this “hours” earlier And eventually all the FXing produces some major heavy-lifting for the encode and a requirement for greater BitRates and consequently larger files.
Rule One: Capture with the best lighting you can. I have several kit bags of lighting. A set of LED Panels; top lights; fill and LED spots. I’ve also rigged an anonymous floor standing standard lamp I rigged with a controllable incandescent. I like that one!
Rule Two: Use a heavy or at least a “stiff” Tripod. I have a 10 year old MILLER with carbon fibre legs which I use rigged to a Dolly.
.Rule 1000: Optimise Encode appropriate/suitable for platform.
But hey, these rules are only guidelines. Personally I’d swap R1 for R2 ????
And again Derek, do take up John’s suggestion of a DI. This DI then becomes THE file to encode from. For me this gives me a cleanly QA media created the best way I can output. And then I can encode knowing what I’m dealing with. Also the encode times are massively reduced.
* Grazie
