Activity › Forums › Apple Final Cut Pro › Watch out! 10.0.4 upgrade warning…
Ivan George replied 14 years, 4 months ago 7 Members · 15 Replies
Eric Santiago
April 15, 2012 at 4:26 pmSorry David just read this post.
Did you get it resolved?
I still have one machine here 10.0.3 if you need. -
David Battistella
April 16, 2012 at 7:37 amThanks Eric,
Still no resolution on this one.
I have the files sitting on a site for download if anyone wants to help out.
They all opened in 10.0.3 but no luck in 10.0.4
Everyone should also be aware that if you have ONE corrupt project in the project list, then it appears that NOE of the other projects in the list will open.
Through a series of tests, I have found that once the corrupt project is isolated then the rest of the projects open fine. It’s figuring out which one is corrupt.
It’s a good thing I run EVENT MANAGER X, because it streamlined the testing process.
I’m also in touch with Apple on this, so hopefully we can discover what went wrong.
I wish I could revert back o 10.0.3 for about two hours, but alas, I discovered my time machine partition was backing up “another drive with an old OS” .
Thanks for all the help so far and hopefully I can get this resolved.
Usually these upgrades are no problem at all, but this one project is giving me some grief at the moment.
David
______________________________
The shortest answer is doing.
Lord Herbert
https://www.davidbattistella.com -
David Battistella
April 17, 2012 at 10:56 amI managed to get the project opened in a copy of .3 and generated an XML file.
The XML file gives me this error message:
Lord Herbert
Ivan George
May 14, 2012 at 1:21 pmSorry if this is a little off topic but for $299 are we guinea pigs for Apple? Seems like every update we need to find a work around rather then focus on being creating and just edit. Sorry for the rant, please continue to dissect as I’ll keep reading.
