Activity › Forums › Apple Final Cut Pro Legacy › Walter or Shane 1 PVM-14L5 Question
  • Tony
    October 20, 2007 at 12:24 am
    Boris,
    For color correction accuracy you will need to use a monitor probe to calibrate the monitor’s gain and bias controls.
    I use one for both my 14L5/1 and 20L5/1 with great results.
    Tony Salgado
  • Walter Biscardi
    October 20, 2007 at 12:36 am
    [tony salgado] “For color correction accuracy you will need to use a monitor probe to calibrate the monitor’s gain and bias controls.
    I use one for both my 14L5/1 and 20L5/1 with great results.”
    FWIW, we don’t use a probe. We use the old fashioned Blue Gun method. 65+ HD Broadcast Masters and 100’s of SD Broadcast masters down with no complaints from Quality Control and kudos from network presidents for our image qualit.
    So it can be done without the probe if need be.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Chris Borjis
    October 20, 2007 at 11:09 pm
    [walter biscardi] “FWIW, we don’t use a probe. We use the old fashioned Blue Gun method”
    same here.
  • Tony
    October 21, 2007 at 4:10 pm
    Walter and Boris,
    Great to hear you like what you are getting but please be aware without an accurate method to align the monitor from the get go it very difficult to even know if your color temp and contrast settings are even right. FYI I use my probe in the field for shoots as well as in post for accurate, repeatable results.
    Blue check has nothing to do with calibrating a monitor’s gain and bias controls.
    Once you have tried out a monitor probe and understand what it has to offer the experience will open up a greater understanding of the value it has to offer.
    In the end a monitor probe is yet another tool which allows repeatable results which can be tracked over time.
    FYI major telecine and color correction suites rely on the use of a monitor probe for their monitor alignments.
    I have found most of the Sony monitor I tested right out of the box are too blue and color temp is 7700K or higher.
    Tony Salgado
  • Chris Borjis
    October 22, 2007 at 3:29 pm
    what do you recommend Tony?
Page 2 of 2
