Activity › Forums › Adobe After Effects Expressions › Video to ASCII effect
Olivier Vincent
August 29, 2008 at 1:08 amIt works beautifully well!
It took me a while (as a pure beginner to AE) to get it properly working… But now I managed to play with the ascii definition, color, etc…
This is a very elegant script.
Thanks a lot!!!
Eric Manevy
November 15, 2008 at 5:52 pmGood evening Patrick
i’m very interesting about your ascii .aep project , i tryed to download it but i think it has been removed from the site.i’m novice with expressions and got the same probleme with syntaxe ( where must i put this code in the text layer ? ) ,Arrgh ! would you be able to join this project again, it woud help me very much in my work !
Thanx a lot for your help
Eric from Paris -
Patrick Deen
November 15, 2008 at 7:07 pmHello Eric,
First of all, I can’t take credit for the script as it was written by Dan Ebbert but I did upload my source file for everyone to use in their own project. And for you…. I’m uploading it again. I think that all questions that may arise are answered in the previous post. Remember to use a mono-spaced font and have it aligned to the left. If you want to know what everything in the script means you should read the commented version of the script a few posts up…
Good luck with it and enjoy…. and don’t forget to thank Dan 😉
reuploaded ascii file:
https://rapidshare.com/files/164094989/ASCII_EXPERIMENT.aep -
Eric Manevy
November 15, 2008 at 9:32 pmMerci beaucoup, tanx a lot Patrick and Dan for all this informations ,now i can begin my work on ASCII , i will make a good experience with your project patrick, and it’s moving !!
Eric -
Emmanuel Kowandy
September 11, 2012 at 7:04 pmHello Patrick,
I am a new After Effect user, CS5 version.
For a VJing project, I search a ASCII Art effect.
I found this old post, I tried it but with no success.Your download source (ASCII_EXPERIMENT.aep) does not exist any more.
Can you post a new link?Thank you for your help.
Emmanuel from Arras -
Patrick Deen
September 11, 2012 at 7:38 pmHello Emmanuel,
Sorry to inform you I no longer have the project file. All you really need to know is here in this thread.
You need a comp with a video called target and a textlayer with Dan Ebberts expression in the sourcetext property. (just cop-paste it from the thread)(Check for my version of the script with comments to get an idea what does what in the script)
Good luck,
Patrick
Emmanuel Kowandy
September 11, 2012 at 8:22 pmThank a lot for your answer so quickly.
I will try again.
Thank you very much.
Emmanuel -
Patrick Deen
September 11, 2012 at 8:46 pmI though I’d check if I could recreate this thing. I can’t seem to get it to work either. This was made with cs3 or cs4. I might have a backup somewhere. I’ll post it if I can find it.
Emmanuel Kowandy
September 11, 2012 at 10:01 pmOk, thank you Patrick.
I have test your method, a composition with a video called target and a textlayer with Dan Ebberts expression in the sourcetext property.
But without result.
Perhaps I forgot something.
Here a link towards a screenshot of my After Effect : https://lalettrek.com/capture.jpg
This is a french version of AE.
Emmanuel
Dan Ebberts
September 11, 2012 at 11:19 pmIt works for me once you add the backslash before the “r” in the line
s += “[insert backslash here]r”;
Dan
