Activity Forums Avid Media Composer Video Out
  • Shane Ross
    August 9, 2011 at 3:45 pm
    Compressor. But I might have to try the Export to ProRes right from Avid option…see if I can bypass this gamma thing.
    Shane
  • Shane Ross
    August 9, 2011 at 9:46 pm
    Ooooo…exporting to ProRes DOES get rid of the gamma issue. Nice. Now this is a pretty slick workflow.
    Shane
  • Jeremy Loftus-hills
    August 9, 2011 at 11:35 pm
    ThanksShane. I’m nearly there except I can’t get Color to see the converted (to pro res) clips. Is it enough to just tell it where the output from Compressor is, or does it need to know here the clips themselves are?
  • Shane Ross
    August 9, 2011 at 11:40 pm
    After you convert the footage to ProRes, you need to open the EDL manager in Avid, and export an EDL of just the video layer…CMX3600. Then open Color…import the EDL, and it will ask for the accompanying media file. Point to the file then.
    Are you saying you imported but it doesn’t see it? Red X over the footage?
    Shane
    August 9, 2011 at 11:44 pm
    That’s right. Red X on what would otherwise be a clip.
  • Shane Ross
    August 9, 2011 at 11:49 pm
    Make sure it is ProRes, and proper dimensions and frame rate. Not some non-broadcast format. Open the file in QT, or even FCP and look at it.
    Shane
    August 10, 2011 at 12:16 am
    YES!!! The pro res conversion checked out OK, but what I had overlooked was an EDL import radio button in Color – ‘Import as cut list’. I checked that and then all clips came into Color just perfect. Do you know what the gamma shift is? I found setting master Gamma somewhere between 0.7 and 0.8 set it back where it was. Maybe Compressor can be set so no shift occurs? Thanks Shane that’s a few steps too many but under the circumstances keeps a great correction program alive and well for a us as we make the change to Avid.
  • Shane Ross
    August 10, 2011 at 12:25 am
    [Jeremy Loftus-Hills] “Do you know what the gamma shift is? I found setting master Gamma somewhere between 0.7 and 0.8 set it back where it was”
    I don’t…I guess I should. I found that Master gamma too, and set it back as well. That’s how I corrected the gamma shift in Color, and dragged that to all the clips, used it as the base.
    [Jeremy Loftus-Hills] “that’s a few steps too many but under the circumstances keeps a great correction program alive and well for a us as we make the change to Avid.”
    Hey, save a step and export ProRes out of Avid MC. Saves a layer of compression, and the file is ready for Color then. So Avid directly to Color, render, go to FCP just to get it out of Color, export as a self contained file in FCP, use AMA to get that back into Avid MC…transcode…, add titles and graphics…done. Similar to what you’d have to do in Resolve, or if you output to tape.
    So glad that I can still use Color…
    Shane
    August 10, 2011 at 12:41 am
    OK but how do I export with Pro Res Codec. No such option available on export drop down list. Ref file is exporting with original codec which in this case is XDCAM EX. Is there a setting somehwere deep inside AVID where I can customise the export parameters?
  • Shane Ross
    August 10, 2011 at 12:46 am
    If you have Final Cut Pro on the same system, it should be there. Near the Avid DNxHD codecs.
    Shane
Page 2 of 3
