Activity Forums Apple Final Cut Pro Legacy video desaturation playback stopped
  • Andy Mees
    January 20, 2006 at 11:39 am
    if this is indeed your issue then Kurt is absolutely right
    there is a nasty bug with overlays causing levels to shift, i’ve noticed it specifically with the range check overlay
    simply turning it off fixed the problem for me
    fwiw on closer inspection i found the level shift also happened on the computer monitor (but was far more pronouced on the external monitor)
Page 2 of 2
