Activity › Forums › Adobe Encore DVD › Verifying 24p flag
Joe Bowden
May 8, 2006 at 8:01 pmI had it sort of backwards (apologies).
24p MPEG-2 is supported, but it should have the pulldown flags for 29.97 fps on a non-progressive display. The big advantage to using it is you can encode to MPEG-2 with less compression (and higher quality), since there are approximately 6 fewer frames per second.
I cannot claim expert knowledge in this area, so I’ll defer to any experts here, and advise researching more online if you have more questions.
Mark Weaver
May 8, 2006 at 8:40 pmJoe,
Now this makes sense. Never thought about it though. You
could definetly get more onto the DVD. Hmmmm… Interesting.
Always more for me to learn. Thanks very much for digging
up this answer.By the way, you work for Adobe right? Well, as I’ve said,
in the surveys they’ve sent me Encore is a great tool. Even
though I’m still learning, I can get it to do everything
I want to. 🙂Thanks again for the help.
Mark
