Vegas Pro 18 Stability
Posted by Matthew Jeschke on August 23, 2020 at 3:45 amOkay, I have a decent machine. There’s another post on here about my setup. It’s no slouch. I ran every update with Vegas for the most part, the last being Vegas Pro 17 and now I’m running 18.
I am elated to see how much better the timeline playback is in 18. However, I’m about to cry. It crashes CONSTANTLY. I can barely use the software. I also cannot figure out what’s provoking the crash. It seems to come at completely random times.
Anybody else tinkered with this Vegas Pro 18 and figured out how to make it run well?
I do Architectural Photograph & Cinematography as a part of being a Residential Real Estate Consultant.
Some of my work can be seen at,
http://www.youtube.com/keystoaz/
http://www.vimeo.com/matthewjeschke/
http://www.keystoaz.com/PS. It\’s an excellent excuse to ride off what I love, Camera equipment 🙂
Matthew Jeschke replied 5 years, 3 months ago 5 Members · 11 Replies -
Steve Rhoden
August 23, 2020 at 4:48 amVegas Pro 18 is rock solid for me the first day out the gate on it’s release, and solid for many other users as well, but equally it is very unstable for many and crashing frequently like what you are experiencing!……… Thus the problem lies in how each user’s computer is configured with which GPU hardware or with which drivers.
There are tons of recommendations to try over on the Magix Vegas forum regarding this issue, so do a search on the related topic.Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia -
Matthew Jeschke
August 23, 2020 at 4:57 amInterestingly, I made some progress immediately after I posted this thread. I found a thread on Vegas Forum website. I cannot seem to find it again. Had customary stuff, turn this off, try that, etc. etc. etc. I tried some of the itmes:
1. Turned dynamic ram preview to 0 MB – NO HELP
2. Closed Project Media & Explorer Panes – NO HELP
3. Lowered Render threads to 12 – NO HELP (but keeping that way as I only have 6 cores, 12 with hyper threading).Lastly I updated the Radeon Drivers for my RX480. I had latest release of drivers from 2019, however, they came out with a newer literally a couple weeks ago. Version 20.8.1.
Hasn’t crashed since I updated the graphics driver.
Will post as I learn more. Hopefully that was the solution, as I’m really liking this silky smooth REALLY fast timeline playback in 18.
Steve Rhoden
August 23, 2020 at 5:26 amGlad updating the drivers worked for you. If your Vegas becomes stable after updating the drivers, then you need not worry about things going bad again….. That is the solution in your case!
Matthew Jeschke
August 27, 2020 at 3:02 amI spoke too soon. It ran rock solid for about a day. Now it runs for about 5 minutes and randomly crashes. Only things I notice crashing it consistently:
1. Task switching
2. Clicking too fast in application on timelineAny ideas are welcome. My workflow is completely destroyed with this crashing so much. I wish vegas had a support line?
Matthew Jeschke
August 31, 2020 at 1:48 amMy problems have become even worse now. The software won’t even load. It takes about 10 attempts to load it before it launches.
Anybody know of a support number? Anything for Magix? Another forum with perhaps some of the software developers on it?
Mike Kujbida
August 31, 2020 at 2:23 amhttps://www.vegascreativesoftware.info/us/vegas-pro-forum/ is my go to forum. Lots of knowledgeable users with periodic visits from MAJIX employees.
There are stickies at the top of the page to check out first. Then do a forum search. If you still need help log in and ask your question.
Good luck. -
Matthew Jeschke
September 9, 2020 at 10:16 pmMike thanks for forum referral. I made a login on VegasCreativeSoftware.info and post. Honestly, nobody really has much advise to offer. However, I did make a breakthrough on this.
I noticed Magix is responsive on their Facebook Page. I posted my question about 18’s stability there and they gave me an email for customer support: infoservice@magix.net
Oddly enough, the software started behaving as if all on it’s own though. It still has occasional crash, but nothing like it was before. I’m just baffled. Must have been something in Windows 10 that got updated in background.
Here’s a link to the post I created on other forum as well: https://www.vegascreativesoftware.info/us/forum/vagas-pro-18-keep-crashing–123536/#ca769268
Douglas Spotted eagle
September 11, 2020 at 10:21 pmI too, have many issues with Vegas 18’s stability. NewBlue crashes the system often, but that’s nothing new. However, I have learned that if i disable all other calls in the system, I can *usually* improve the stability.
There is also a potential for Vegas 18 to be having problems as this machine has Vegas 8-18 on it. Although none of the others are loaded, they are indeed, installed.
Killing all background apps, setting RAM to 0 (if any images/stills are being used), will help with stability.
Matthew Jeschke
April 25, 2021 at 6:12 pmThanks Douglas, I didn’t see your post till just now. Last couple updates from Magix seem to have increased stability a bit further. I’ll keep in mind to kill all background apps.
FYI ~ I don’t have all those versions of Vegas installed but I have several. I should really remove the extras to free up space but I have plugins that are only licensed to older versions 🙁
Dimitrios Papadimitriou
April 26, 2021 at 7:53 amThe latest update for 18 helped with stability for me too. I’m not crashing nearly as often.
