Activity › Forums › VEGAS Pro › Vegas plugin not loading properly
  • Jack White
    March 28, 2017 at 10:20 am
    Yup, tried all all those things including resetting the entire pc and updating the drivers to no avail. Guess I’ll have to stop using VP
  • Graham Bernard
    March 28, 2017 at 10:24 am
    [Jack White] “Guess I’ll have to stop using VP”
    ‘Cos of one FX? Yup, I’m guessing you will have to.
    * Grazie
  • Jack White
    March 28, 2017 at 10:34 am
    It’s not just one FX, it’s almost all of the fxs that fall under the title “colour gradient”
  • Graham Bernard
    March 28, 2017 at 11:25 am
    [Jack White] “It’s not just one FX, it’s almost all of the fxs that fall under the title “colour gradient””
    This is a Generated Media. In your first post you state that it s with VP13 Build 453. However your ScreenGrab is from VP14. What build of VP14 are you trying?
    Here’s mine:
    * Grazie
  • Graham Bernard
    March 28, 2017 at 11:35 am
    Jack, try this. Not saying it WILL work, but, try changing your Columnar View to 2 Columns – click on the one next door:
    * Grazie
  • Jack White
    March 28, 2017 at 11:50 am
    Tried that, didn’t work actually, the changing buttons of 1 column to 2 columns are solid, and doesn’t get pressed but I managed to change by going to another FX and coming back, but no use.
    Just tried most of the fxs.
    The problem extends to
    Color gradient
    Credit roll
    Test pattern
    (Legacy) text
    VP 14 build 161
    VP 13 build 453
    Tried on both
  • Graham Bernard
    March 28, 2017 at 12:00 pm
    [Jack White] “VP 14 build 161”
    Latest Build here is 211. Did you download that? But before you do this try deleting VP completely off of your system – AT YOUR RISK! – prior to rebooting and then installing Build 211.
    I’m trying here! – You DO see that mine is working.
    * Grazie
  • Jack White
    March 28, 2017 at 1:05 pm
    Tried that, deleted VP completely and re installed the latest (211) . Still the same.
    And I really do appreciate all your help.
  • Jack White
    May 7, 2017 at 4:07 pm
    Hey,…
    So update : finally got it to work, updated to windows 10 creators update, and launched Vegas again. And voila… The problem has been solved.
    Once again gonna thank thee for your help.
Page 2 of 2
