vegas 13 with 5.1 wavs to Adobe Encore CS6
Mike Peterson replied 11 years, 8 months ago 2 Members · 18 Replies
John Rofrano
December 24, 2014 at 8:13 pmDo you have DVD Architect Pro? If you just have Vegas Pro without DVD Architect Pro that may be why.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Mike Peterson
December 25, 2014 at 4:02 amWell it sounded good, but unfortunately I installed DVD Architect Pro, rebooted, ran both in administrator mode and without, and still had the customize option greyed out 🙁
It really sounded like the solution though.
John Rofrano
December 25, 2014 at 1:08 pmSomething isn’t right. You should be able to edit the templates. I would contact Sony support to see if they can figure it out.
~jr
Mike Peterson
December 25, 2014 at 5:14 pmYeah it is strange, also I have two computers with it installed and both behave the same so it isn’t an installation issue.
Mike Peterson
December 25, 2014 at 5:48 pm8329_capture.jpg.zip
OK I found that in my Vegas Pro 12 I had additional templates names DD AC3 PRO as opposed to DD AC3 STUDIO and the PRO templates I can edit. So all I have to do now is locate my 12 templates and copy those into 13 -
John Rofrano
December 25, 2014 at 7:46 pm[Mike Peterson] “OK I found that in my Vegas Pro 12 I had additional templates names DD AC3 PRO as opposed to DD AC3 STUDIO and the PRO templates I can edit. “
Yes, you didn’t mention that you were using the Studio templates. You need to use the Pro templates of you want to edit them.
~jr
Mike Peterson
December 25, 2014 at 8:22 pmBut what is strange is I don’t see the PRO templates in VP 13 – I see the directory in the file I/O but it doesn’t show up. I tried to import the AC3 templates into 13 but achieved only errors. My solution right now is to recreate the project in 12 and use the PRO output which seemed to work fine. Just a little disturbed that I can’t render PRO right from 13. 🙁
