Activity › Forums › Apple Final Cut Pro Legacy › Varicam 24P online issues
  • Ben Squires
    February 13, 2007 at 7:48 pm
    Hi Gary,
    Yes, I’ve aready changed the 720P easy set-up to 60 rather than 59.94 and I’m not sure which boards are in the machine as such, But it has on add on card on the left of the machine which supplies a firewire i/o and HD input, 2x out and SD out x1 – i’m assuming this is the ‘both’ firewire and HD board you refer to. Still, within FCP i cannot get the FPS to 60, it still states 59.94 in the vid rate column of the bins when i capture it. Still, if i change menu 030 to 1 ( 60 FPS) no video shows in the capture window. I really can’t see what else I’m doing wrong here and it’s driving me up the wall !! ;(. I have also tried changing the device control preset for DVCpro HD to 30, not 29.97. The only other odd thing is in the capture summary for my editted ( 60 not 59) preset – it says ‘firewire using NTSC’ ??. I apologise if this is turning epic but I am still no nearer to solving this, despite your kind help.
    Regards,
    Ben
Page 2 of 2
