Activity › Forums › Adobe After Effects › Using REFlex motion morph
Pierre Jasmin
August 9, 2010 at 7:22 pmWhen you run the installer did you select [x] After Effects CS4?
It should show up in the RE:Vision Effects folder in the Effects menu.It should place the plugins automatically here:
C:\Program Files (x86)\Adobe\Common\Plug-ins\CS4\MediaCorePierre
Matthew Hansel
August 9, 2010 at 7:26 pmThanks – Pierre!
Much appreciated! I’ll try to locate it
in the plug-ins folder before I post next
time to see if it even installed…I”ll repost soon w/my discovery either way…
Thanks again,
~Matt H>
Paul Boyd
August 13, 2010 at 5:34 pmHi again Pierre,
As we get deeper into the morping process, we’re running into some problems: as objects pass in front of one-another there is all kinds of distortion that happens. ie. a hand passes in front of a face during the morph and everything goes all mushy.
We’ve discovered that doing a separate comp for every problem shape will do the trick, but it’s super time consuming and we’ll have a big compositing job to do at the end of the morphing.
Can you think of another way to clean these problem spots up?
Paul SG Boyd
Pierre Jasmin
August 13, 2010 at 7:11 pmYes some work involved…
Sometimes you can use the boundary shape but there is only oneIn case if you have to do multi-pass morph, and you move a front layer in a way that leaves small holes, you can use RE:Fill Area to cover up the background hole.
Pierre
Paul Boyd
November 14, 2010 at 7:20 pmHi Pierre,
Here’s the finished spot that i directed and did the post on for a spec competition.
Your plugin came through.
Enjoy!
https://www.youtube.com/watch?v=FJs-1bKzMVYPaul SG Boyd
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
