Activity › Forums › Apple Final Cut Pro Legacy › Using full resolution of large still image
Ashley Albertson replied 17 years, 2 months ago 5 Members · 12 Replies
Jason Brown
July 14, 2009 at 5:08 pmGo to Sequence -> settings. The compressor used is down on the bottom left.
I found a good one to use that is pretty common is DVCPro HD…that codec kept a lot of things in real time…and the pictures could stand a lot of scaling with a small amount of loss.
Ashley Albertson
July 22, 2009 at 8:58 pmim not sure i have the same settings as you… i have options like DV Ntsc 48kHz, DV PAL 32 kHz Anamorphic, Apple Intermediate Codec 720p25… will any of those help the situation?
