Activity › Forums › Adobe After Effects › Using expressions to create stepped graph
Jt Pase replied 13 years, 6 months ago 2 Members · 11 Replies
Jt Pase
March 5, 2013 at 12:33 pmThank you very much for your help on my problem. Luckily in the end, my client just decided to go for a more accurate visualization so I ended up using audio beam which is much simpler. I’ve attached a frame of what I ended up.
I haven’t solved the problem of using particular, I would actually think that since the particle has been already emitted, changing the amp or frequency parameter should only change future particles so I didn’t expect the weird behavior I got.
In any case, that’s a bridge I shall cross if I have to do something similar in the future. Thanks very much for your time and help on this, it’s much appreciated!
