Activity Forums Apple Final Cut Pro Legacy Using Casablanca With FCP
  • Mark Beazley
    October 5, 2005 at 2:22 am
    I knew I should not have read the manual or actually looked at the digitizing options…silly me. 😉
    -mark
  • Nick B
    October 5, 2005 at 11:16 am
    ghetto
    What your trying to do is not realy editing as we editors know it !
    If Casablanca does what you need then use that, the quality will be ‘good enough’ for what your trying todo i suspect.
    That said in FCP select the roll tool (looks like an 8 ) click on the edit type in -30 (this trims the edit 30 frames back) right click on mouse which gives a mini menu and select add dissolve job done.
    I reckon it would take you less than 5 seconds to do each edit.
Page 3 of 3
