Activity › Forums › Apple Final Cut Pro Legacy › Uploading 20 Gb. of raw footage?
Mark Petereit replied 15 years, 6 months ago 13 Members · 24 Replies
Thomas Frank
February 17, 2011 at 10:39 amIDSN be faster then DSL???
WOW in our Country we make fun of People that still use ISDN…😉
Paulo Jan
February 17, 2011 at 12:15 pmYes, this.
I thought of that idea (encoding to H264) after I went to bed last night, and today I’ve been doing some tests. It’s workable… I think. The only problems I’ve seen so far are:
-The default H264 encoding preset in Compressor outputs a progressive file (it deinterlaces automatically), which is a no-no in our case.
-File sizes aren’t as small as I expected. With the default H264 preset, the resulting file is around half the size of the original, which means that it’s still 10 Gb.
-Also, there’s the gamma shift.We’ve also been asking around and found some companies with faster Internet connections that can give us a hand, etc., so I think we’re out of the woods. Thanks again to everyone who responded.
Rafael Amador
February 17, 2011 at 1:12 pm[Paulo Jan] “-The default H264 encoding preset in Compressor outputs a progressive file (it deinterlaces automatically), which is a no-no in our case.”
Paulo,
You are a Pro. Stop using “Default presets” and learn how to customize them.[Paulo Jan] “-File sizes aren’t as small as I expected. With the default H264 preset, the resulting file is around half the size of the original, which means that it’s still 10 Gb.”
Limit the data rate and ALWAYS set Key-Frames Auto.
With a 10Mbps (10.000Kbps), your file will be reduced to 4GBs.
Being SD, you can still reduce it.I would recommend you trying “HandBrake’ for the H264.
– Supports Interlaced.
– Supports H264/High Profile.
– Accepts DVCPro50 sources (No prores).
rafael -
Paulo Jan
February 17, 2011 at 2:32 pm[Rafael Amador] “Paulo,
“Oh, I did that :-). Problem is, the interlaced version takes more space than the progressive one. With the default preset, the resulting file takes 50% of the original. With the default preset, modified to disable frame control, it takes about 60% of the original.
Paulo.
Rafael Amador
February 17, 2011 at 4:05 pm[Paulo Jan] “Oh, I did that :-). Problem is, the interlaced version takes more space than the progressive one. With the default preset, the resulting file takes 50% of the original. With the default preset, modified to disable frame control, it takes about 60% of the original.”
Paulo,
From Interlaced to progressive can not be any big difference in file sizes. On both you are dealing with the same number of pixels per frame, so you need the same data to write the info.
The key for the file size is on the data-rate and the k-frames you set on the H264 compressor.
rafael -
David Roth weiss
February 17, 2011 at 5:23 pm[Paulo Jan] “I thought of that idea (encoding to H264) after I went to bed last night, and today I’ve been doing some tests. It’s workable… “
Not a good idea!
1) h.264 encoding is very slow on your side.
2) h.264 is not an editing codec and will need to be transcoded to another codec on your client’s end.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
https://www.drwfilms.comPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
Joey Burnham
February 17, 2011 at 7:21 pmI agree with Dave. Satellite it or even maybe fiber feed if they are willing to pay.
You inquired earlier about how large studios are sending huge files to one another these days. Basically, you get what you pay for regarding internet service. We just upgraded to copper internet lines for $$$ but our upload speeds are about 2 MB a second. A gig only takes about 10 minutes or less to go up.
Joey
David Roth weiss
February 17, 2011 at 8:09 pm[Joey Burnham] “Basically, you get what you pay for regarding internet service.”
I completely agree… Trust me, when Spielberg wants to see his dailies, the studios pay, and he can see them anywhere.
It’s all about what you’re willing to pay for the luxury…
David Roth Weiss
Los Angeles
Paulo Jan
February 18, 2011 at 2:06 pmI know it sounds strange, but as God is my witness: take a 1.4 Gb. test clip in DV. Encoded with the default H264 setting. Result: 683 Mb. Take the default setting, copy it and disable frame control, in order to prevent deinterlacing (and leave everything else the same). Result: a 854 Mb. file.
Keith Pratt
February 19, 2011 at 1:56 amPaulo Jan: “Encoded with the default H264 setting. Result: 683 Mb. Take the default setting, copy it and disable frame control, in order to prevent deinterlacing (and leave everything else the same). Result: a 854 Mb. file.”
Is that because you’re using the ‘automatic’ setting for data rate, and deinterlacing is cutting down on the resolution/detail the H.264 encoder will try to retain?
