Activity › Forums › AJA Video Systems › Upgrade to OSX 10.6.1? Upgrade to Kona3 Control Panel 7?
Brian Deviteri replied 16 years, 10 months ago 3 Members · 19 Replies
Walter Biscardi
October 22, 2009 at 7:10 pm[Brian DeViteri] “Have you installed the AJA Kona3 control panel? I’m using version 6.0.1 – this seems to be the only one that works fine… “
Of course we have the control panel, can’t work in Final Cut Pro without it. You need the control panel to set up the card for inputs, conversion, etc…. We’ve always run the control panel on every single workstation.
[Brian DeViteri] “The “ImporterAJA” is the default when importing video into AE. When you drag video in, it imports using the same “ImporterAJA”. “
I honestly have no idea what you’re talking about. File > Import files > Select the video files on the hard drive, they pop right into AE.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author.
HD Post and Production
Biscardi Creative Media“Foul Water, Fiery Serpent” now in Post.
Creative Cow Forum Host:
Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital. -
Jeremy Garchow
October 22, 2009 at 7:16 pmBrian-
I think I have it figured out now. You are talking about the spearate AJA CS3 and CS4 drivers. The control panel as we all know it is the actual control panel for the card, which looks like this:
What you are talking about are what is referred to the AJA Mac Plugins for CS3 (or CS4). As I said, I don’t use those as I have never really liked how they behaved with AE. I just use the Kona card in the video output of the AE preferences.
Jeremy
Brian Deviteri
October 22, 2009 at 7:16 pmHere’s a screen shot of where the “ImporterAJA” appears when importing a standard 720p DVCPRO HD Quicktime Movie under Adobe CS3 with AJA Kona3 and control panel 6.0.1 installed.
Under 6.0.1 the footage imported into AE is pristine and clean.
Under 7.x the footage imported into AE looks like an offline, blocky mess.
Jeremy Garchow
October 22, 2009 at 7:19 pmWhat I think you need to do is uninstall the CS3 plugins and install the CS4 plugins.
You need the 6.5 Kona drivers, not the Kona v7 drivers.
Have a look here down at the utilities and options:
https://www.aja.com/support/kona/kona-3-3x.php
Jeremy
Brian Deviteri
October 22, 2009 at 7:23 pmMy original plan was to do a “clean install” of 10.5.8 then FCS3 and CS4, but time constraints will not let that happen… so I have to clone the drive and then upgrade the new drive.
I’ll install CS4 and then Kona3 version 7 and just HOPE I don’t get those same issues. Will let everyone know how it goes…
Walter Biscardi
October 22, 2009 at 7:28 pmNope, don’t use that option, never have. Everything imports as a standard Quicktime Movie using the native codec. Here’s what it looks like on my system.
Not sure why you would ever use that AJA Importer option.
Jeremy Garchow
October 22, 2009 at 7:37 pm[Brian DeViteri] “I’ll install CS4 and then Kona3 version 7 and just HOPE I don’t get those same issues. Will let everyone know how it goes… “
It says very clearly on the AJA website to use the v6.5 drivers if you are going to use the CS4 plugins. I would install the v6.5 drivers and then the AJA plug-ins.
Don’t go to 7, sorry I was wrong before as I didn’t know what you meant. If you have installed 7, simply uninstall 7 and reinstall 6.5. the v6.5 drivers work with FCS3.
Drivers:
https://www.aja.com/ajashare/AJA_Kona3_6.5.zip
CS4 Plug-ins:
https://www.aja.com/ajashare/AJA_Adobe_Mac_6.5.0.mpkg.zip
jeremy
Brian Deviteri
October 22, 2009 at 7:44 pmI have not yet installed the Kona drivers for CS4, so thanks for the heads up. Appreciate it. Nothing has been downloaded from AJA for the upgrades yet either, so hopefully I might have caught that at some point. Unfortunately, I haven’t even gotten around to starting the install on that system yet – ahh, another really long day…
I would just forgo installing the plug-ins all together, but we’ve used the AJA color tools quite a bit in the past (they work great by the way) and not having them available may be an issue when it comes to opening archived projects.
Brian Deviteri
October 22, 2009 at 7:45 pmFrom what I’m gathering, apparently it was installed when the AE plugins were installed – if I had the option, the “ImporterAJA” would not have have been installed…
