Activity › Forums › VEGAS Pro › Unwanted crop/zoom
  • Stephen Mesureur
    April 29, 2017 at 6:06 pm
    Hello Eric,
    My videos are in 3840*2160, and my project is 3840×1646, so it’s just a cut in Y axe, no crop/zoom.
  • Stephen Mesureur
    April 29, 2017 at 6:08 pm
    John, you understand well 🙂
  • Stephen Mesureur
    April 29, 2017 at 10:09 pm
    Here are some images to explain :
    1. is what I have (zoomed image)
    2. is what I should have : 3840×1646 from 3840×2160 image
    I still don’t know why but I notice that it occurs only with GOPRO footages… Not with RX100 ones.
  • Stephen Mesureur
    April 30, 2017 at 4:23 pm
    News : it happens on the same file !
    So weird…
  • Aleksey Tarasov
    April 30, 2017 at 4:55 pm
    Can you share your file? I’d like to test it
  • László Kovács
    April 30, 2017 at 8:24 pm
    Maybe that file is corrupt in a way?
    What happens if you add that file to a brand new empty project?
    I also would try to repack/remux it without reencoding:
    ffmpeg -i that-file.mp4 -vcodec: copy -acodec: copy output.mp4
    (or even to different container, say .mov)
    See if that helps?
    Best regards
    László Kovács
  • Stephen Mesureur
    April 30, 2017 at 8:47 pm
    Hello !
    Tha’s what I did few days ago, vegas lossless (or close) conversion then it was ok.
    And my last sequence was weird because on the same footage that I have cut (S) in the middle, first part was cropped and the 2nd, not !!! (same track of course)
    So I deleted the first cut-part, recut the 2nd and find my start scene back.. and it was ok… even after aply 21/9 format…
    Strange…
    Here is one file :
    https://we.tl/FIWmCQSzAL
    Thank you because I’m curious.
  • László Kovács
    April 30, 2017 at 8:58 pm
    Just thinking:
    is that the last file from that cam? Is there a chance, that the cam was shut down abnormally?
    (I think something like switching off before stopping REC, or run out of battery?)
    I’m downloading your sample anyway…
    Best regards
    László Kovács
  • Stephen Mesureur
    May 1, 2017 at 6:18 am
    Hello and thank you to help me ☺
    It’s not tha last file but you are right, it could be a bad-stop gopro files, it happens sometimes.
    I’ll try to make a video this morning to see better this case ☺
    have a nice day László
  • Aleksey Tarasov
    May 1, 2017 at 8:40 am
    I tested your clip and I don’t see the problem.
    Your clip 3840×2160 (16:9)
    Your project 3840×1646 (21:9)
    You will get pillarboxes or cropped image (if you match output aspect in pan/crop window)
    Everything works as it should.
Page 2 of 3
