Activity › Forums › Adobe After Effects Expressions › Uniform Scale Wiggle
  • Uniform Scale Wiggle
    Posted by Adriano Moraes on July 1, 2008 at 4:04 pm
    Hello there.
    I think it´s a pretty simple thing but I can´t find it anywhere.
    I guess I´ve even done this before but my brain is failing me.
    So what I want to do is simply make a circle´s scale
    wiggle uniformly(x and Y with equal values).
    How do I achieve that?
    Sorry if there are answers allready in the cow, but I could not find it.
    Ok, thanxxx allready and cheers.
    a.ninguem.
    Dmitriy Finn replied 2 years, 10 months ago 9 Members · 14 Replies
  • 14 Replies
  • Dan Ebberts
    July 1, 2008 at 4:39 pm
    Like this:
    w = wiggle(5,30);
    [w[0],w[0]]
    Dan
  • Adriano Moraes
    July 1, 2008 at 5:57 pm
    Thank you Dan!
    I gotta visit Motionscript.com a little more (and deeply) and finally LEARN the stuff.
    Thanx again.
    Cheers.
    a.ninguem.
  • Gon Perdigao
    June 4, 2013 at 8:36 am
    Mr Dan you are a master 🙂 !!!!
  • Vincent Rogozyk
    November 18, 2013 at 6:56 pm
    Hi Dan,
    Is there a way to make the uniform wiggle loopable?
    Thanks a lot for your help.
    Best Regards,
    Vincent
  • Dan Ebberts
    November 18, 2013 at 7:28 pm
    This should work:
    freq = 1;
    amp = 110;
    loopTime = 3;
    t = time % loopTime;
    w1 = wiggle(freq, amp, 1, 0.5, t)[0];
    w2 = wiggle(freq, amp, 1, 0.5, t – loopTime)[0];
    linear(t, 0, loopTime, [w1,w1], [w2,w2])
    Dan
  • Vincent Rogozyk
    November 18, 2013 at 7:37 pm
    Thanks a LOT.
  • Mil Malchiodi
    January 29, 2014 at 3:51 pm
    Thanks a lot Dan!
    -MiL-
  • Rod Duarte
    February 23, 2021 at 4:29 pm
    Hey all!
    I’m trying to use this, and I’m getting a syntax error on line 6…
    I’m guessing AE changed something, since this is old?
  • Dan Ebberts
    February 23, 2021 at 4:42 pm
    I think the site redesign text formatting must have substituted a different character for the minus sign in line 6. Try it this way:
    freq = 1;
    amp = 110;
    loopTime = 3;
    w2 = wiggle(freq, amp, 1, 0.5, t - loopTime)[0];
  • Angus McCracken
    May 17, 2021 at 6:24 pm
    this is crazy, I’ve learned a bit of scripting and thought – I can handle this.
    So I typed :
    i=wiggle(2,5);
    [i[0],i[1]]
    Doesn’t uniform scale.
    So I paste your code:
    w = wiggle(5,30);
    [w[0],w[0]]
    and it works.
    Spaces? i not w? What’s the deal? Does AE think ‘that’s some Dan Ebberts code so make it work.
