Activity › Forums › Adobe After Effects › unable to import .mp3 files into AE CS3… help?
Trev Chee replied 15 years, 6 months ago 5 Members · 12 Replies
Trev Chee
February 22, 2011 at 4:55 amI’m new to editing videos in premiere and AE CS5. Hoe do the pros combine the audio and video? For example I want to do a title sequence and want the different title texts to be timed with the musical cues and sfx in the song. Do I create animation in AE with music? or animation only in AE then drop into Premiere with audio? If the latter is correct, how do i adjust the timing of the animation to the music if it’s already exported as a composition?
thanks
T -
Trev Chee
February 22, 2011 at 4:58 amSO how do you get the timing right when synching the audio to a title animation where the text must move on cue to music cues and sfx? Do you drag both audio and premade title animation into Premiere? if the latter is correct how do you tweak the animation to fit in with the audio?
thanks
T
