Activity › Forums › Adobe Premiere Pro › ultra wide screen multimedia show
Ansel Spear
February 27, 2013 at 12:30 pmHi Morten
Excuses for jumping on this bandwagon…
I have been asked to produce a 12273 x 1080 Watchout comp split into 8 sections (projectors), each incorporating a 441px overlap.
I have produced a 12273 template in AE CS6, but cannot find a way of splitting the comp into 1080 sections.
Your experience would be appreciated.
Thanks.
Morten
February 27, 2013 at 5:33 pmWe normally assemble the comp as you have done in After Effects, and then crop the output upon export.
You could also PreCompose the entire sequence in 8 different 1920×1080 comps, moving it on the X-axis (the required amount of individual pixels) for each comp. The result is the same, but the latter makes it easier to export again after changing something.If you have 12273 x 1080 comp that spans across 8 displays, you can calculate the individual pixels by first subtracting 1920 pixels: 12273 – 1920 = 10353. You can now calculate the amount of pixels outside the overlap: 10353 / 7 = 1479. And now we can get the overlap: 1920 – 1479 = 441 pixels.
You know that the first output starts in pixel “0”, and ends at “1920” – it needs to be cropped 10353 pixels in the right side.
The second one starts at pixel “1479”, and ends at 1479 + 1920 = “3399”. So if you precompose, simply move the large comp 1479 pixels in the 1920×1080 comp – or if you crop, you will need to crop 1479 pixels in the left side, and 12273 – 3399 = 8874 in the right.
The third starts at 1479 + 1920 = 3399.
I guess you can figure out the rest…
– No Parking Production –
2 x Finalcut Studio3, 2 x Prod. bundle CS6, 2 x MacPro, 2 x ioHD, Ethernet File Server w. X-Raid…. and FCPX on trial
Ansel Spear
February 27, 2013 at 6:13 pmThanks Morten.
…And the scales fell from my eyes and I could see!
Much appreciated.
