Margie Marfi
September 21, 2005 at 6:59 pmHi Edward,
This is getting so long I didn’t know if it’d be better to start another question… but it’s still me. I did the cuts and deletions..camera switches, etc. Ran the multicam wizard and it moved only about the first two minutes up to the Master track .. then went back to the muli pip … which was not on the Master Track, it was below on the pip track. I do know that my marker flags ..nos 1 and 2 were at the start and 3 had the content marked “end” then I had about 26 camera switches inbetween those two extremes. Didn’t know if that’s the problem. Removed the #3 “end” updated tally indicator ..if that did anything and got the same result. If that’s the problem is there anyway to automate renumbering all the marker flags in the proper order from start to end?
Edward Troxel
September 21, 2005 at 7:04 pm
