Activity › Forums › Apple Final Cut Pro Legacy › Tweening in FCP5
Zak Mussig
January 4, 2007 at 2:46 pmrafalaos,
How would you make a 15 fps sequence in FCP 5.1.2? If you look in the Sequence Settings window, the only options for timebase are 60, 59.94, 30, 29.97, 25, 24, and 23.98. If you select 15 fps in the compression (codec) settings window it ignores it and tells you to set that in the Sequence Settings window, where 15 doesn’t seem to be an option. Is there somewhere else to set this or a way to include other options? I said I was unsure, but I’m pretty sure of what I’m looking at… I just don’t like the answer. I would like to be able to make the framerate any arbitrary number if I ever have a special need.
Zak
Rafael Amador
January 5, 2007 at 1:35 pmYes Zack. Im wrong. I don’t know why I have that idea.
sorry.
salud,
rafael
