Activity › Forums › Adobe Premiere Pro › Trying to open Premier Pro CC file on CS6 but project is damaged
Oscar Honorio replied 10 years, 5 months ago 9 Members · 14 Replies
Alain Alfaro
November 13, 2013 at 5:58 pmI just tried exporting an XML for someone trying to open the project in CS6 and it worked fine.
Immanuel Heims
June 25, 2014 at 9:35 amI found the following work-around: not perfect, but quite good.
Premiere 6.5 projects can be directly opened in CS6 or earlier just by changing the extension from .ppj to .prproj
Make a copy of the original .prproj file and name it Name_audio-only.prproj
Export sequence(s) as FCP XML from CC – multiple sequences can be selected OR select Project Panel to export entire project (Attention: Most video – even intrinsic ones like motion, opacity etc. and audio effects are not correctly translated! Check beforehand that all 3rd party plugins are installed in all versions of PPro!)
Save a copy of the project as Name_video-only.prproj and delete all audio tracks or audio clips from all sequences that contain video effects
Close PPro CC project
If the PPro CC project file is compressed, add .gz as extension and extract with 7zip
To disable compression in CC:
Ctrl + F12 to open Console, switch to Debug Database View: BE.CompressProject> false
Open in Notepad++
Edit version number change (4th line) from 26 to 23 or 24 and open the project in PPro CS5.0.3 or PPro 5.5.2 and save it.If there should be a color picker dialogue box while opening click Cancel (as this is most probably for Adjustment Layer which are not supported in CS5.5)
If PPro CS5.5 shows a Log of non-translated effects etc., copy and paste them into a text file with the project name for later reference.
PPro Version numbers:
23>CS524>CS5.5
25>CS6
26>CC
27>CC 2014
A simple change to 23 and opening it directly in Adobe Premiere Pro CS6 does not work! (Liegt wahrscheinlich an den Audiotracks, da Projekte mit Sequenzen, die nur Video enthalten, teilw. geöffnet werden können.)It is possible to open a PPro CS6 project directly in CS5.5 by editing the version number from 25 to 24.
Open this project Name_video-only.prproj in Adobe Premiere Pro CS6 and convert it to CS6 project – now you have all the sequences with the supported video effects
Import FCP XML project file(s) into PPro CS6 and copy the audio tracks from the corresponding sequences (or vice versa: copy video tracks so they align synchronously again)
Gotcha’s:
Through Edits, Adjustment Layers, Time Remapping, 3rd party filters, plugins, transitions may not be correctly translated!
PRPROJ File AssociationsAfter installing an update to PPro, Windows will change the default program to the latest program version, e.g. CC. If you want to revert those to CS6, you cannot simply do it with Rightclick>Open with>C hange default program..
There is a way to change the setting in the Windows Registry:
Open regedit.exe as Administrtor
HKEY_CLASSES_ROOT/Adobe.Premiere.Pro.Project. > shell/open/command and change the path in “” to the correct program version.
You can also do a search in the section of HKEY_CLASSES_ROOT/Adobe.Premiere.(with various endings following the word “Premiere”) and change all remaining instances.
creative media & more, Germany
Videography ❘ Postproduction ❘ Media Design ❘ Photography
MEHR ALS BEWEGTE BILDER. BILDER, DIE BEWEGEN!https://www.immanuel-heims.com
https://vimeo.com/heims/albums/sort:alphabetical/format:thumbnails.d.g.
Rob White
July 1, 2015 at 9:02 pmI know it’s for AE, but I thought with the new releases you can go between one version to the next. ONLY one generation however.
Oscar Honorio
April 13, 2016 at 4:32 pmHi, friends. the xml project is sufficient. But the graphics is imported in pixel aspect ratio 0.9. In CS6 project is possible change a 1.0.
The audio settings is changed a two audio tracks.
Todo is Ok
