Activity › Forums › Apple Final Cut Pro Legacy › truly beginner FCP questions
Tom Wolsky
January 13, 2007 at 9:35 pmGet Carbon Copy Cloner. It’ll clone your system drive. Run the installer onto the external and it should be OK. Do not try to install just the application onto the external and try to run it from there. You need to be booted onto the drive or partition that has the Application folder with the app.
