Activity › Forums › Adobe Illustrator › Transparency – says its 100% but its not
Jesse Byerly replied 8 years, 9 months ago 13 Members · 13 Replies
Al Thinn
October 5, 2016 at 12:09 pm(Accidentally found a quick and easy solution to this which keeps all your bezier curves – on mine at least…)
Just Press D
Problem solved.
Steven Levesque
November 13, 2017 at 4:47 pmI’ve been struggling with this too and although this post is 4 years old, adding what I managed to resolve this in case other people read this.
In the Layers panel:
1. Select the layer or layer group you want to set to opacity 100%,
2. look at that circle at the right of where you name your layer, click that, hold, and drag left.Maybe drag right or whichever direction works but this worked for me. See screenshot below:
Jesse Byerly
November 22, 2017 at 7:56 pmI think I figured it out!!! ????
So, the solution for me was in the “Appearance” panel. Once I selected ONLY the element I was having a problem with, and looked at it in the “Appearance” panel- I saw the words “Overprint” next to only that element. So, I just went to the bottom of the “Appearance” window and deleted the effect, and the problem went away!
