Activity Forums Apple Final Cut Pro Legacy Transparency lost when importing PNG into FCP
  • Transparency lost when importing PNG into FCP
    Posted by Nathan Padgett on March 16, 2009 at 5:44 pm
    Strange thing keeps happening when importing a transparent PNG into FCP. Images created with the same settings in PS will sometimes mysteriously end up with a black background when taken into FCP.
    There seems to be no rhyme or reason for this. It seems to be a random occurrence, but happens enough that it’s problematic. Going back to the original PSD and re-saving the PNG under a different file name works most of the time, but sometimes it doesn’t and I have to create an entirely new PSD and then save as a PNG.
    It’s always a “cross your fingers and hope it works this time” type situation.
    Anybody know what’s going on here? Is it a PS setting, a FCP setting? I’m at a loss!
    Thanks in advance!
    Rikki Blow replied 1 year, 11 months ago 17 Members · 20 Replies
  • 20 Replies
  • David Roth weiss
    March 16, 2009 at 7:05 pm
    Is your file being created in Photoshop on a Windows machine?
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Nathan Padgett
    March 16, 2009 at 7:16 pm
    No. I’m using CS3 on either a MacBook or an IMac depending on where I’m working and FCP is running on a G5.
    I can create two images with the exact same PS settings and one will import fine and the other won’t. That’s going into the same FCP timeline/settings too. It’s very strange and very frustrating.
  • Dave Schweitzer
    March 16, 2009 at 11:35 pm
    Are you importing fresh or reconnecting to an existing PNG?
    Sometimes when I’ve made a change to a graphic, overwriting the original and keeping the same name, upon reconnect to the new file FCP loses track of the transparency.
  • Nathan Padgett
    March 17, 2009 at 2:54 pm
    Importing fresh file with slightly different file name. (test_1.png, test_2.png, test_3.png, etc.) Sometimes this works. Sometimes it doesn’t.
  • Brandon Ivey
    February 16, 2010 at 10:13 pm
    The same thing is happening to me, running FCS 6. It dosent happen all the time, but when it does, that project is shot and I cant use any transparent images. What is the deal?
  • Nathan Padgett
    February 16, 2010 at 11:31 pm
    Unfortunately I never got a clear answer as to why this was happening.
    It seems the best way to reduce the risk of problems is to make sure all your settings match between PS and FCP.
    so if your FCP project is say, DVCPRO HD 720p then your PS settings should be for DVCPRO HD 720p or 960×720 with 1.33 pixel aspect ratio.
    Making sure the file settings are the same eliminates a lot of “unknown” problems that can occur.
    In a few instances I was never able to get the .png to import correctly and had to import the .psd file.
  • Brandon Ivey
    February 17, 2010 at 2:31 pm
    Actually, I figured out a work around, if not a cure. I spent the better half of an hour looking for this and here is what I found: When you pull the PNG into your time line and it is not transparent, click on the clip and go to the modify option in your menu bar. There, go down to “alpha type” and choose “straight”. I dont know why you have to do it now, but thats what I found works. Hope if helps.
  • Bill Thomas
    March 14, 2011 at 10:48 pm
    Thanks Brandon!!!
    That’s exactly the command I was looking for. This happened a long time ago and I had forgotten what to do.
  • Jimmy Wanamassa
    October 26, 2011 at 5:30 pm
    I can’t even successfully bring a .png into FCP 6. What’s the word?
  • Desiree Damon
    November 29, 2011 at 2:48 pm
    Wow, this solution sure saved my day. Thanks for posting it.
