Activity Forums Adobe Premiere Pro Transition help need
  • Transition help need
    Posted by Fahim siyam on September 8, 2025 at 10:21 pm
    Can anyone teach me this mirror slide/ wipe transition? No video on youtube, only about slide transition, but i want this mirror border below. I found this preset online, but it only have down slide. plz help
    Devrim Akteke replied 1 year ago 3 Members · 16 Replies
  • 16 Replies
  • Devrim Akteke
    September 9, 2025 at 8:00 am
    Do you have a video showing what you need? It’s hard to understand what you mean by a still frame.
  • Fahim siyam
    September 9, 2025 at 9:44 am
    sure, here it is, ” https://youtube.com/shorts/mF2rj15A9T8?si=sQ9k1m24Vy8zJs0r ” . look closely, when the image slides to another there is a reflection . i found only one video on internet saying you need sapphire plugin to do mirror / reflection effect. but then i found a free preset doing the same, without plugin.direction But it is one directional , just down, can you help me to slide the to every direction , up. left , right.
  • Fahim siyam
    September 9, 2025 at 9:49 am
    here is the preset; https://drive.google.com/file/d/1GsPxhZqZWyuVI3Ca8zg42448uwz3k1IT/view?usp=drive_link . the transitions is under wrap section, and just disable the brightness/ contrast fx
  • Devrim Akteke
    September 9, 2025 at 10:41 am
    Well, it’s basically changing X and Y values. This one changes Y values, so it moves vertically; if you change X values on keyframes, it will move horizontally. But also, there is the mirror wrap effect; you have to play with those, too. If I have some time, I will try to modify it and let you know.
    September 9, 2025 at 11:44 pm
    Hey Fahim,
    Adding to Devrim’s advice, I would also “play” with the reflection angle.
  • Fahim siyam
    September 10, 2025 at 6:29 am
    yeah, got it , but when ever i try to change offset value. thing get messy. can you please tall me what would be the offset value for up, right, and left
  • Devrim Akteke
    September 10, 2025 at 11:33 am
    The numbers I used in the sample I sent are:
    960×540 — 0x540 — 1920×540 — 960×540
    This is for horizontal, I am changing only X values and keeping the Y values intact.
  • Fahim siyam
    September 10, 2025 at 1:53 pm
    thank you very much , sir. much appreciated
  • Fahim siyam
    September 11, 2025 at 6:37 pm
    Dear akteke sir
    would you please remove the YouTube link from our previous discussion? as this kind of video is against my values and I do not want to promote them, but i don’t find any way to edit the post
    September 11, 2025 at 6:46 pm
    Dear Fahim,
    You’ll need to explain why that video goes against your values, as I can see nothing wrong with it?
    In fact, you had no problem with it whilst you were seeking help, so it is double standard then to ask for it to be removed, right?
    Just making an observation.
    Not a judgement on your moral code or religion.
