Activity › Forums › Apple Final Cut Pro Legacy › transcoding H.264 sequence to ProRes
  • Diane Collins
    October 12, 2010 at 5:25 pm
    Hi, Do these specs work for Canon 5D files too?
    Description: Apple ProRes 422 10-bit video with audio pass-through. Settings based off the source resolution and frame-rate.
    File Extension: mov
    Estimated file size: 30.92 GB/hour of source
    Audio Encoder
    16-bit Integer (Big Endian), Stereo (L R), 48.000 kHz
    Video Encoder
    Format: QT
    Width: (100% of source)
    Height: (100% of source)
    Selected: 1280 x 720
    Pixel aspect ratio: Square
    Crop: None
    Padding: None
    Frame rate: (100% of source)
    Selected: 30
    Frame Controls: Automatically selected: Off
    Codec Type: Apple ProRes 422
    Multi-pass: Off, frame reorder: Off
    Progressive
    Chroma filtering enabled
    Pixel depth: 24
    Spatial quality: 50
    Min. Spatial quality: 0
    Temporal quality: 0
    Min. temporal quality: 0
  • Catalin Brylla
    October 12, 2010 at 10:38 pm
    Diane,
    There is no point using ProRes 422. You can use ProRes 422(LT), which still has a higher data rate than the H.264 files you transcode (which are 8-bit only).
    Use the EOS plugin for FCP to transcode via Log&Transfer. Saves you using Compressor.
    Catalin Brylla
    Filmmaker – Editor – Lecturer
    http://www.catalinbrylla.com
    Mobile: 07789004745
    Skype: cbrylla
Page 2 of 2
